Old 08-30-2012, 10:11 PM
kootenaycat kootenaycat is offline
Vehicle: 2012 Ram 3500
kootenaycat is on a distinguished road
Default 2012 Ram 3500 Speaker Upgrade
Had the truck for a month and I finally got around to replacing the factory door speakers in the Cummins. Still have to find dash speakers, thinking of tweeters only instead of a full range 3.5", and next will be new head unit, amps and sub. I've got the factory sirius subscription that I don't want to just throw away so going to have to live with just speaker upgrade for now.
I put Rockford Fosgate T152 in the front with the supplied adapter plates and T1692's in the back which fit with just a slight mod to the window regulator support. Definitely have better high end sound but surprisingly I don't notice any improvement in bass, maybe lost some if any. Thinking the Fosgates need some real power behind them to work, so when I get around to installing an older Pheonix Gold 4 channel for the doors it should improve.
As for wiring colours I used the AA battery trick to decipher polarity and this is what I found:
LF + grey/yellow
- grey/purple
RF + green/yellow
- green/purple
LR + grey/dark green
- grey/light green
RR + green/pink (don't have my glasses but it looks pink!)
- green/yellow (again without glasses it looks like faint yellow)
And I have the base radio/non-alpine setup with no sub, just 6 speakers
A few pics, I forgot to get pics of the fronts with the new speakers but got the rears
LF door panel off
6x9 LF speaker hole
RR 6x9 installed
Comparison of stock to new
Old 09-01-2012, 12:34 AM
Chunkem's Avatar
Chunkem Chunkem is offline
"New Cummins here we go"
Trim Level: Longhorn Rambox
Rep:1648
Nicely done.....
Old 11-02-2012, 12:58 PM
kozzy kozzy is offline
Vehicle: 2016 Ram 3500 Big Horn
Color: Delmonico Red
Engine: 2016-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 900lb/ft (Aisin ASC69RC Automatic)
kozzy is on a distinguished road
What's the AA battery trick? Just curious.
I'm in the process of upgrading my 2012 2500 diesel big horn
Old 11-02-2012, 02:43 PM
Jon3sgte Jon3sgte is offline
Vehicle: 2012 Ram CC
Trim Level: Tradesman
Rep:30
Jon3sgte is on a distinguished road
If I'm not mistaken, the factory speakers are 2ohm. If this is the case and you are using 4 ohm speakers then you are definitely going to notice a difference in the output of the new speakers-especially with the bass. Yes, an amp will definitely let the new speakers play to their full potential.
Old 11-06-2012, 12:56 AM
ONOutdoorsman's Avatar
ONOutdoorsman ONOutdoorsman is offline
Vehicle: 2017 Jeep Grand Cherokee
Trim Level: Laredo 75th Anny
Color: Billet Metallic
Rep:388
ONOutdoorsman is just really niceONOutdoorsman is just really niceONOutdoorsman is just really niceONOutdoorsman is just really nice
2 ohm speakers only for Alpine system I believe. Base is 4 ohm.
A good set of 2 way dash speakers will make a world of difference for the higher frequencies.
No More RAM
Old 11-06-2012, 08:07 PM
Rep:30
^Ok, I stand corrected. Thanks for the info!
Old 11-10-2012, 06:33 PM
05bee729's Avatar
05bee729 05bee729 is offline
Vehicle: 2012 ram express
Trim Level: express
Rep:26
05bee729 is on a distinguished road
replaced my dash speakers with Polk DB351 sound 1000 times better. only speakers ive changed so far. huge diff for sure. id say spend the money for sum decent 3.5 not tweeters
05 dumble bee #729 homemade pvc intake. superchips programer. ls1 fbody efans, 100 shot, leaf springs clamped front and rear
Old 11-10-2012, 08:42 PM
Rep:388
I am amazed at the difference a good set of 3.5" 2 way speakers make in this truck. I've been listening to a lot of the same music for over 30 years and I'm hearing stuff that I've never heard before. Like in Bring it on Home by Zeppelin for example, I don't recall ever hearing what sounds like drum sticks tapping together to the beat during the verses.
No More RAM
Old 11-13-2012, 11:47 AM
Rep:30
Did you get this figured out?
It could be possibly that one or more of your polarities are off. One more thing you could check/rule out.
