Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Dodge Ram Decals
Old 08-31-2012, 01:46 AM
Nck's Avatar
Nck Nck is offline
Vehicle: 2nd Gen 2002 RAM 2500 24V
Trim Level: Laramie SLT
Color: Light brown/Goldish
Rep:74
Nck will become famous soon enough
Default Super fast turn signal. ?
I got some LED brake light bulbs today to replace the stock bulb.
So now left and right turn signals are insanely fast, what could cause this?
I'm thinking making the computer is doing something, but I'm not to sure.
Any solutions?
Old 08-31-2012, 06:54 AM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
You need a new relay. Led's take less power then stock bulbs. So solid state relay is a bit lost.
Old 08-31-2012, 10:24 AM
UNBROKEN's Avatar
UNBROKEN UNBROKEN is offline
Vehicle: 2012 Ram R/T
Trim Level: R/T
Rep:123
UNBROKEN will become famous soon enoughUNBROKEN will become famous soon enough
With the low current draw of LED's your truck thinks it has a bulb out.
When it does that with regular bulbs in place that's your hint that one burned out.
Old 09-01-2012, 01:55 AM
Nck's Avatar
Nck Nck is offline
Rep:74
That's kind of what I started to think. I might just get new and brighter stock bulbs, call it good with LED's.
Old 09-02-2012, 08:07 AM
ramfam's Avatar
Trim Level: Base
Rep:21
You can keep LED'S just need to get a relay that's electronic insted of solid state.electronic ones if they have the right output for LED'S will operate with normal flash and brightness of incandesent bulbs. The way things are going we will have to all be mandated by govermint to go to LED or CFL'S to save gas or some bird no ones herd of.
Old 09-02-2012, 08:32 AM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
I like mine to flash fast (at least twice per second). This way I can hit it and then cut some inconsiderate SOB off. If it flashes slowly then I have to drive like 1/4 mile to be sure they see it, make a decision as to if they're going to respond, finalize the decision on responding, speed up and block me because they are the most recent heir to the throne somewhere. Slow down and let me in so I can just turn and be on my way and hopefully never see them again. Or make the decision for them because their head is up their a$$ and they're driving with their feet on the steering wheel, and stuff them into the guardrail.
I like fast signals.
Old 09-07-2012, 08:38 AM
Vic Vic is offline
Vehicle: 2009 Dodge 1500
Color: Dark red
Vic is on a distinguished road
You can get the digital flasher unit everywhere and just plug it in.
Vic
Old 09-14-2012, 06:03 AM
Nck's Avatar
Nck Nck is offline
Rep:74
I just recently put the bulbs back in, plus there a lot brighter than the LED, because the bulb lights up the whole compartment, rather than just straight out.
Old 09-17-2012, 01:41 PM
Asur Asur is offline
Vehicle: .
Rep:4373
You can put LED's but you need to find LED 3157 type Bulbs that are at least 400 lumen, they are hard to find, but not impossible, get them with minimum 30 x 5050SMD LED's also you will need a resistor between the body and your Positive to make the load like a normal bulb, you can find these on ebay or places like ****************. Look for LED Load Resistors
