2004 ram 1500 leveling kit? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram 4x4 - Offroad Discussion
Old 08-31-2012, 02:32 PM
teddyrev teddyrev is offline
Vehicle: 2004 dodge ram
Color: silver
teddyrev is on a distinguished road
Default 2004 ram 1500 leveling kit?
I have an 04 ram 1500 am I better off to buy the leveling keys, or crank mine up a couple turns? as far as the ride.. and what size tires could i clear?
Old 08-31-2012, 11:17 PM
crazychevy88 crazychevy88 is offline
Color: silver
crazychevy88 is on a distinguished road
I think with the leveling kit you can fit up to 33's under your truck. I wouldnt recomend tightening up the torque keys just because it changes alot of your front end geometry, however the leveling kit does basically the same thing.
Old 08-31-2012, 11:23 PM
krazybone krazybone is offline
Vehicle: 2010 ram 1500 4x4
Trim Level: Laramie/Sport/SLT
Color: Metallic Silver
krazybone is on a distinguished road
i have a 2005 which is the same specs as a 2004 and i researched and all at once i cranked my stock keys untill they were level then replaced upper ball joint lower ball joint that were worn and wheel allignment.
i clear 45 by 12.5s on a 17 inch rim no problem. mud tires to with big lugs. i dont have any pictures for u at the moment they are all on my phone
k
Old 09-01-2012, 09:42 AM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
Cranking the stock keys and buying new indexed keys does the same thing. I would save the money and hassle of new keys and just crank away. I would adjust them moderately and not raise it any more than it takes to get the look you want. For me it only took about 1-1/8". I too was worried about the ride but I didn't notice any negative affects after doing mine. Make sure you get an alignment after.
As for tires, the stock 20" tires are 33" so you can fit those or even 34's without the level. With the level you should be able to clear 35x12.50.
Old 09-03-2012, 03:20 AM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:80
Like it's been mentioned, crank the stock keys and save the money for something else. Cranking the stock keys or replacing them with indexed keys nets the same result. Ive cranked many keys in the past and as long as you keep it mild (2" or less) you should be fine. Get an alignment and if you want to improve the ride quality get some new shocks (often overlooked maintenance that makes a big difference in ride quality).
2007 6.7 | EFI-Live | Draconian tuned TCM | T4 S366 | ARP | AFE | Fox | Carli
