Old 09-18-2012, 09:27 PM
Aaronswitzer Aaronswitzer is offline
Vehicle: 2011 dodge ram
Trim Level: St
Aaronswitzer is on a distinguished road
im not sure where the front lighting harness is
Old 09-18-2012, 11:24 PM
Asur Asur is offline
Vehicle: .
Rep:4373
I am tapping into the wire directly at the light source at the front of the truck, I have still not found the front connection in the Red Connector or any of the connectors at the Fuse area, due to the BCU on these trucks you can't easily find connection points, I had found the Rear ones but not the front ones, this forced me to have to go and get the connection wire right from the wire that links the front turn signal, I had to remove the headlight unit from the front and tap into the wire directly there to get a good Turn signal "signal", hope that helps. Next week I should have more time to recheck the fuse connection box to find the right wires, till then, I tapped it direct.
Old 09-20-2012, 08:45 PM
Rami Rami is offline
Vehicle: Ram2012
Trim Level: Express Quad Cab
Color: gray
Rep:12
Rami is on a distinguished road
WOW!! Excellent info. This is something I'll do also.
Asur, where did you get the side rear view mirrors and how bright the lights are at night/dark?
Regards!
Old 09-21-2012, 02:08 AM
Vehicle: .
Rep:4373
These are the original mirrors that you can get when you order your ram, some have these and they remove them to install Towing mirrors. I bought this set off a guy who did just that, I had only the standard mirrors that have no puddle lights and no turn signals. The puddle lights are pretty decent, mostly when its dark outside and no lights on around the truck, they light up the ground pretty good, They are LED's not spot lights so they are limited, but they do what they are made for, I like them. The turn signals are good also, that is mostly why I wanted them.
Old 09-21-2012, 11:28 PM
Vehicle: Ram2012
Color: gray
Rep:12
Nice! Great idea about getting someone that had to replace those. Now I'll be searching for someone like that too.
Thank you, Sir!!
Old 11-25-2012, 02:34 PM
Rgl21 Rgl21 is offline
Vehicle: 2009 dodge ram
Rgl21 is on a distinguished road
Pictures aren't working and I really wanna do this D:
Old 11-25-2012, 02:43 PM
Vehicle: .
Rep:4373
pm me with any questions, Photobucket lost my account, pictures went poof
Old 11-25-2012, 02:48 PM
fastNugly @ BP fastNugly @ BP is online now
That blows.....did you get any of it back?
Old 11-25-2012, 02:56 PM
Vehicle: .
Rep:4373
nope nothing, there service said it was not there problem as it was a new site and there not responsible for content, they said they would try and retrieve the images from previous backup but that has been a month now
Old 11-25-2012, 03:02 PM
That SERIOUSLY BLOWS!!!
