Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
Old 09-01-2012, 01:38 PM
Deke602 Deke602 is offline
Vehicle: Dodge Ram B250 SE 5.9L 360
Trim Level: Royal SE
Color: Blue
Engine: 1981-1988 360ci (5.9L) LA V8 170hp
Deke602 is on a distinguished road
Talking Dodge Ram B250 5.9L 360
Ms. Big Cactus is still down. I took her to the hospital and the doctors just don't know what to do about her. I've replaced every part which makes her heart go and still no spark. I'm stumped the doc is stumped.
If anyone knows about the electrical systems of mid 80's mopar. I would certainly like any advice on what may be the problem. No spark from coil.
She's a Dodge Ram B250 5.9L 360 with only 84,000 miles.
Replace:
ECM, Distributor, coil wire, starter relay, ignition with tilt, ballast resistor. Still Ms. Big Cactus is not rolling. The carbs getting gas.
Old 09-01-2012, 06:32 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
I see an item missing from the list of replaced items....the coil itself. Being a mid 80's, I would expect the coil to be in need of replacement if it's the original.
brad
Interested in one of my mods?
Old 09-01-2012, 07:05 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
.or the ballast resistor.....
Old 09-01-2012, 07:23 PM
brad12kx's Avatar
Rep:2581
Originally Posted by Deke602 View Post
Replace:
I saw something that Warlock missed!
Sorry Drew.....I had to do it! You usually don't miss that stuff so I just had to capitalize on it!
brad
Old 09-01-2012, 08:59 PM
Vehicle: 95
Rep:1776
I didn't exactly miss it...they suck right out of the box!
I'll concede a for catchin' it though...credit where credits due
Did you bring it up to TDC and make sure it's not 180 out? And plug in the dist?
Old 09-01-2012, 10:16 PM
brad12kx's Avatar
Rep:2581
OK, OK....I'll give you that one. LOL They are not the most reliable off the shelf part.
Good call on the timing thing. When replacing a distributor that is an easy error to make as the timing mark is at TDC twice for each distributor rotation. Only one of this times is it right!
brad
