Old 09-02-2012, 05:00 PM
FF54 FF54 is offline
Vehicle: 1998 Dodge Ram
Color: Ford Woodland Green with black added
Rep:26
FF54 is on a distinguished road
Default Offroad Clutch
Hey guys and gals. So as some of you know I did a motor swap in this truck back earlier this year, in doing that I also put a clutch and flywheel in it. Well, the clutch acutally feels like its warped and the throwout bearing is junk already too. I was wondering what yall are running for clutches in your truck. The reason I came here instead of the normal forum is this truck lives off road, just about every weekend we're doing trail rides or playing in the mud. The last clutch I put in it was just one of the best quality ones you can get off the shelf at advance auto parts, but it was only a single disc. Im looking to put a dual disc in it seein how this one has slipped a few times on me out in the woods. Any suggestions?
Old 09-02-2012, 07:47 PM
TRCM's Avatar
TRCM TRCM is offline
Vehicle: 2012 Ram Laramie 4x4 CC
Color: White w/silver trim
Rep:63
TRCM will become famous soon enough
South Bend..........they specialize in diesels, but also do gas trucks too
http://www.southbendclutch.com/truck_catalog.html
1996 Cherokee Sport 4x4
1988 Cherokee Pioneer 4x4
Old 09-04-2012, 11:12 PM
Rep:26
Any other suggestions? I know there has gotta be more suggestions then that.
Old 09-05-2012, 10:44 AM
dezertrunner dezertrunner is offline
Vehicle: 2001 Ram
Trim Level: Base
Color: Blue
dezertrunner is on a distinguished road
It's a 360.. You really don't need a special clutch. Honestly an automatic is better for many off road situations, as they have a little bit of "give" due to the torque converter.
Old 09-05-2012, 04:59 PM
TRCM's Avatar
Rep:63
And don't forget the torque multiplication factor of the torque converter. A good aftermarket TC can double the torque available.
Old 09-05-2012, 11:31 PM
Rep:26
Your right, but I dont own an automatic, and Im not converting it to one. And with as many of this generation dodge automatics I have seen being loaded up onto a tilt bed Im not sure I could ever bring myself to own one. Especially since just two weeks ago I towed a stock truck, same year and motor, that was an automatic out of the woods with a junk trans, that just reinforces it. And I realize that it is a 360, I built it. I have already put one clutch in it, and it needs another one, and its only been six months. When im wheeling, or woking it or anything, I do it in low range in first or second gear so its not like i was slipping the clutch or anything. I was just looking to see what everyone else is running for clutches or their suggestions. I can't find a vendor for South Bend anywhere around here.
Old 09-05-2012, 11:38 PM
TRCM's Avatar
Rep:63
Almost any diesel performance shop should carry them...there are 13 in PA listed on the south bend website
http://www.southbendclutch.com/distributors.html#pa
And you can build an auto to hold the power you make. Many of the parts used in the diesel auto trans will also work in a gas auto.
I had a BB 727 built using a lot of diesel trans parts that would hold a twin turbo'd 12v ctd. Just have to find someone to build it, or do it yourself.
It can be done, if you want to (and it didn't cost anymore than a regular performance rebuild really). The biggest cost on my rebuild was the CRT full manual reverse valve body & HP pump
Vehicle: 2001 Ram
Trim Level: Base
Color: Blue
You "built it". So is it still a 360?
It sounds like you got a bad clutch. That isn't a high power motor, there's no reason it should be eating clutches like that. Unless it's the way you're driving it.
