Dodge Ram Decals
Old 09-03-2012, 12:36 AM
JwhiteH JwhiteH is offline
Vehicle: 2001 Ram 1500 Sport
Rep:15
JwhiteH is on a distinguished road
Angry RANT!!! Leaking Coolant
I have been chasing a coolant leak for the past two months... I thought it was the thermostat housing/gasket... replaced that... still leaked and got worse.. Then Timing chain cover which it isn't. I replaced the water pump sinice the weep-hole was wet... then upon fixing that... It is still leaking...
It is leaking from ABOVE the water pump.. The gasket appears to have come out of the housing on either side of the T-stat. Maybe I over Tightened? It is $4 and I am at my wits end... If this doesn't fix it I am taking it back to the dealer...
On a plus... My Led tails and third look great and I am planning on Plasti-Dipping the grey rocker panels and front bumper.
Old 09-03-2012, 09:32 AM
SnoopyIsMyHero's Avatar
SnoopyIsMyHero SnoopyIsMyHero is offline
Vehicle: 2001 Ram 2500, 2001 Ram 1500
Color: 2500 White, 1500 Black
Rep:97
SnoopyIsMyHero will become famous soon enough
you could have overtightened it, yes. Pull it off, use some permatex on the gasket and replace. don't crank it down tight-tight. Then run it until it gets up to temp and cools down again, tighten it up again. Also, check your freeze plugs. I had one leak on my 5.2.
2001 2500 5.9 4x4. Stock except for exhaust, step rails but I don't care, I love my beast
2001 1500 5.2 4x4. Stock except for exhaust, my new project.
Old 09-05-2012, 03:09 AM
Rep:15
Well... Figured it out.
It was the damn bypass hose. $5 and 5inches worth of hose. Split clean through.
Tada!!! No more leak!
