Old 09-03-2012, 03:13 AM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
Default trans issue
ok guys i have a question, why would a car run rough in reverse only and perfect in drive or park also once in a while it slips im really hoping that its a little issue its my 93 dynasty with the 3.3L mopar v6 the trans is an A604
thanks for any help
Old 09-03-2012, 01:43 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
thanks for any help
If it runs rough or stalls out in reverse only then it is generally something broken that will require transmission removal, it could be a torque converter clutch that is stuck. Now the fact you say the transmission slips and in reverse it runs like crap well you can assume and I can assume it's time for a rebuild.
Old 09-04-2012, 01:07 AM
Vehicle: Jeep GC WK
Rep:964
ok thanks for the help!
Old 09-06-2012, 05:39 PM
ramvan2500's Avatar
Rep:128
You're welcome, and, if you need anymore help I am more than happy too. Hopefully you will be able to fix the transmission, what I would do if you are in a really tight bind with money is to head to a local pick and pull and find a A604 that has low mileage and just swap it.
