starter shorted out - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 09-03-2012, 11:30 PM
Vic Vic is offline
Vehicle: 2009 Dodge 1500
Color: Dark red
Vic is on a distinguished road
Default starter shorted out
The starter shorted out on my 98 1500, 5.9 2 wd.
The main post on the starter arched so bad that it burned completely off.
I replaced the starter, no big deal. When I went to boost it with my 09 Ram the voltage at the cables from the 09 went from 14ish to 0 when connected.
I suspected that the battery may have a dead short in it. I disconnected the neg side of the battery. I connected the positive to the positive side of the battery and grounded the negative to a point in the engine compartment.
Same issue.
I have spent the last 2 days pulling fuses trying to isolate this. The only one that has any effect is the iod fuse, as to be expected.
I disconnected the alternator from the system. No change. I also pulled the connectors from the ecm with no results.
Help would be appreciated.
Thanks, Vic
Old 09-04-2012, 08:35 PM
Chunkem's Avatar
Chunkem Chunkem is offline
"New Cummins here we go"
Trim Level: Longhorn Rambox
Rep:1648
Let us know how you make out and please keep us updated.....
Old 09-04-2012, 10:54 PM
Vic Vic is offline
Color: Dark red
Default Voltage Regulator
I am going to try to change the voltage regulator and see how that goes.
Not sure what else to try.
I have checked the cables and see no issues.
I think that I should be looking for a short somewhere.
I will let you know what I find.
Vic
Old 09-09-2012, 06:29 PM
Vic Vic is offline
Color: Dark red
I found the issue. The module mounted to the top of the alternator was the problem. I went to pick n pull and paid 7 bucks. All is now good and the truck is running like a top.
Vic
Old 09-09-2012, 06:38 PM
Rep:2929
Electrical problems are always fun NOT
i am lucky i guess, there is a shop 2 blocks from me
all they do is Generators, Alternators, Starters, & batteries
they even rebuild them themselves
batteries can no longer be rebuilt in California, so they are sent out to Mexico, reconditioned batteries are also sold at the shop
electrical, starter
