Closed Thread
Old 10-13-2012, 01:14 PM
Originally Posted by ShawnC13 View Post
Probably not until Taxes just an outlay of cash that I do not have
got it.
well im sure it will look good
Old 10-13-2012, 01:18 PM
ShawnC13's Avatar
Cheap Canadian Labour
Rep:1808
Probably going to go with Bilsteins. TRX you can't just get a lift kit as the distances and angles are supposedly a bit different
  #873
Old 10-13-2012, 01:20 PM
id go that route.
i think max for you will be 2" if I am not mistake.
Old 10-13-2012, 01:24 PM
ShawnC13's Avatar
Rep:1808
You are correct. With 3.55 gearing I would have to well want to re-gear to atleast 3.92 if I was to lift and go with bigger tires
here is from the Lift guy in town
Hi Shawn,
Yes you are correct that the trx4 trucks have a different front suspension then the others. There is really only one good way to lift the front of those trucks. That is with the bilstein 5100 series height adjustable strut. Basically the factory trx4 strut is .7" taller then a stock strut so if you try to put a level kit spacer in it over extends everything and can lead to vibrations and other issues. The bilstein strut replaces the longer factory strut and gains about 2" over stock height.
  #875
Old 10-13-2012, 01:27 PM
Unhappy
Hi Shawn,
Makes complete sense to me and the route I'd go.
Plus you have a Bette ride
So it's a win/win
Old 10-13-2012, 01:28 PM
ShawnC13's Avatar
Rep:1808
So it isn't just a level. I would probably actually do the re-gear first then the level
  #877
Old 10-13-2012, 01:32 PM
You don't have to re gear for a simple level...
Old 10-13-2012, 01:34 PM
ShawnC13's Avatar
Rep:1808
No but if I was to go bigger tires. I would rather have it re-geared then level/lift then the bigger tires that way I wouldn't lose any of the Hemi fun factor if I do it in that order
  #879
Old 10-13-2012, 01:38 PM
Makes complete sense.
But do the level first. Then gears. Then tires.
Old 10-13-2012, 01:40 PM
ShawnC13's Avatar
Rep:1808
That actually makes more sense as it is the look of the Rake I want to get rid of first lol
Closed Thread
