Old 09-05-2012, 11:23 PM
linncountyslim linncountyslim is offline
Vehicle: 2004 Dodge Ram
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft (6-Speed Manual)
linncountyslim is on a distinguished road
Default Blend door issue????
My 2004 ram 2500 has an issue with the heater controls. When I switch from vent to feet it works fine. But when I switch to defrost it just continues to blow out the vents. The fan works fine as does the AC although the drivers side seems to blow colder than the passenger side. With the fan on low when I cycle through the different settings I can hear the door closing but when I go to defrost I hear nothing. Yet sometimes when I run the fanon low and move the control from feet to vent to defrost very slow the air will come out the defrost vents as it should but when I increase the fan speed it goes back to the AC vents only. I'm guessing this is the blend door but not sure, any ideas before I tear my dash apart? Thanks for any help.
Old 09-06-2012, 03:13 AM
Rep:2657
Welcome to the RamforumZ
go to YouTube
then type in
HEATERTREATER DODGE
grab your favorite beverage & start watching
they are not the only contributors
