Old 09-06-2012, 06:36 PM
Vehicle: N/A
Rep:1045
Default Track Bars
looking to replace my track bar with something better than factory. I've heard Moog is pretty good.
anyone have any experience with Moog in this manor? or any other better track bars than the oe option
THANKS!
Old 09-06-2012, 07:15 PM
Rep:2616
you might want to at least look at the Hellwigs, i have heard that they were good
http://www.hellwigproducts.com/
Old 09-06-2012, 08:00 PM
Vehicle: N/A
Rep:1045
just ordered a catalog from them! at this point I'm looking for prevention, as well as beefing up parts before they fail
Old 09-07-2012, 11:41 PM
Okiespaniels's Avatar
Okiespaniels Okiespaniels is offline
Vehicle: 2000 Dodge 1500 QC 4x4
Trim Level: Fleet
Rep:47
Okiespaniels is on a distinguished road
I'd go with a 3rd generation replacement/mod kit. Not cheap but you won't ever need to replace another OEM style bar.
You could also do a lindstad mod to your old bar. I did this over 9 years ago and mine is still holding up fine.
http://www.bellefourche.com/lindstad/
Old 09-08-2012, 01:11 AM
Dodge Boy13's Avatar
Dodge Boy13 Dodge Boy13 is offline
Vehicle: 1998 Dodge Ram 1500
Trim Level: sport
Rep:23
Dodge Boy13 is on a distinguished road
i heard skyjacker makes a good one theres on on craigslist by me for cheap last time i loooked
My Build Thread!!
http://www.ramforumz.com/showthread.php?t=118514
Old 09-08-2012, 02:10 AM
Vehicle: N/A
Rep:1045
I know with the Luke's link I have to grind a section off and reweld a new portion on. don't currently have a welder so that's not.looking like it, although that shop is a couple hours from Rapid City lol. certainly wouldn't limp my truck there.
I sent an email to a company called Thuren Fabrication, they have a track bar, but its out of stock. anyone heard of them?
Old 09-08-2012, 04:19 AM
Rep:2616
I never have, so i looked them up
http://thurenfabrication.com/home.html
They are using these companies to sell their products
http://www.google.com/#hl=en&sugexp=...w=1280&bih=687
Old 09-08-2012, 10:21 AM
Trim Level: Fleet
Rep:47
Sadly...I'm told Thuren doesn't make 2nd gen bars anymore. He's been "out of stock" for a couple years. You might check with http://www.dodgeoffroad.com/store_DORtrackbar.php
Danny is a long time 2nd gen fan that has taken up the cause for quality parts. His stuff isn't cheap, but it lasts. It's far better than skyjunker, and as good as anything Thuren used to make.
BTW tell Danny Dsertdog56 sent ya.
Old 09-08-2012, 10:38 AM
Vehicle: N/A
Rep:1045
I've stumbled across that in my searching. I may consider that.
Old 09-13-2012, 01:49 AM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
Lukes links DO NOT require any welding, Wherever you heard that is passing disinformation. It takes about 30 minutes on the bench to install a rebuildable drivers side end on your track rod, and thats if you're holding a beer in one hand. From that point forward, it's totally rebuildable. It also works for tierod ends, I have a pretty good collection of long tierods and old trackrods, but they piled up before I found out about those links, since installing them, I've never had to tighten up or rebuild, or replace them. Some of the best aftermarket money I've spent in my life, just don't beat on the threaded ballstud, when you're removing the assembly, thats the only part you will be reusing. And grease it once in awhile. My trucks are only half tons, if I had a 3/4 ton, and carried a vee plow, I might consider a heavier rod than factory, otherwise, no factor. Once you grind the old factory crimp off,your ballsocket you'll be horrified at the low quality they are initially assembled with. My 2 cents....
