Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
tonneaucovered.com
Old 09-06-2012, 07:00 PM
FDRam01's Avatar
FDRam01 FDRam01 is offline
Vehicle: '01 Ram CC
Rep:13
FDRam01 is on a distinguished road
Default manual tranny noise in an 01 Ram 1500
I've had is tranny whine for a couple months now and is getting loud. I've checked the oil in the trans and it full but needs a changing. I also checked the t-case that is full and looks like it was serviced before I bought the truck 5 months ago. The trans looks like it has never been touched and the truck has 114k on it. I'm trying to find out if anyone else has had this problem and would servicing the trans help.
Thanks.
Old 09-06-2012, 09:28 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Check the fluid in both rears. The rear-rear can travel and make it sound like it's in the trans. I've got 210K on mine and every once in awhile I'll get a short whine for less than a second that sounds like a power steering pump.
Old 09-07-2012, 10:15 PM
FDRam01's Avatar
Vehicle: '01 Ram CC
Rep:13
both are full that was the first things I checked. you can feel a vibration in the stick as well.
Old 09-07-2012, 10:35 PM
Vehicle: 95
Rep:1776
Check your hub bearings. I had one (R/S) front that was going bad and occasionally felt like I was driving on the rumble strips and vibrated BAD in the stick. I was beating my head against the wall, and then the brake pedal felt low, and then it didn't, and then it did, and then it didn't (repeat a few more times). Jacked it up, found the bad bearing and replaced it. Vibration/rumble went away.
Old 09-08-2012, 08:43 PM
FDRam01's Avatar
Vehicle: '01 Ram CC
Rep:13
I'll check that. It only happen when I'm on the gas. As soon as i let off it stops. I think I'm gonna putit on my buddy lift and see if I can track it down that way.
Old 09-15-2012, 10:39 PM
FDRam01's Avatar
Vehicle: '01 Ram CC
Rep:13
Found out today it was not the tranny. The rear diff is done. There was a lot of metal in the diff and 1/4 to 3/8" of play between the ring and pinion gear. Now it comes down to rebuild and regear (cause it has 3.55 gears) or find a used diff and just replace the whole diff.
