Old 09-07-2012, 02:47 AM
Nick and Kels 08 Nick and Kels 08 is offline
Vehicle: 2006 Dodge Ram Megacab
Color: silver
Nick and Kels 08 is on a distinguished road
Default Pre-Filters
I've noticed a lot of guys here do a lot of hard core off roading and was wondering if any of you guys use pre filters. I've used them on all my 4x4 trucks both gas and diesel that have the cold air intakes. Basically they save the filter by repelling water.and keeping the very small particles of dirt out if you live in a desert type environment such as El Paso. My pre filter of choice is made by Outerwears and they have great customer service and if they don't have the pre filter they will build what you want. Just food for thought guys and gals. I've read several post and never read where anyone was using any type pre filter and it doesn't affect the air flow of your CAI at all
Last edited by Nick and Kels 08; 09-07-2012 at 02:49 AM. Reason: grammar and spelling
Old 09-07-2012, 06:48 AM
jacksonsnorth's Avatar
jacksonsnorth jacksonsnorth is offline
Vehicle: 2012 Dodge Ram 1500 QC 4wd
Rep:69
jacksonsnorth will become famous soon enough
That is a very sound idea using a pre filter in that type of environment. I don't have any experience with using them myself, however, it stands to reason that every time you disrupt air flow to your engine it affects the intake. So, even though it may not be a sifnificant change, it would most surely change it some. Just my 2 cents.
The Rammin' Fool from Maine
Stubby Antenna, Bed Net, Toyo Open Country tires, Bilstein 5100 Ride Height adjustable set at 2.1 ..Tow Hooks in house ready for install. More to come!
Old 09-07-2012, 03:20 PM
dezertrunner dezertrunner is offline
Vehicle: 2001 Ram
Trim Level: Base
Color: Blue
dezertrunner is on a distinguished road
Unless you're racing, you don't need a prefilter. I race and I don't even use them sometimes. Also, they might "repel" water to a slight extent, but if air can go through so can water.
Your best bet for filtering is a standard paper type filter. They're is a reason that type of filter has been around forever, they work.
Old 09-07-2012, 04:54 PM
TRCM's Avatar
TRCM TRCM is offline
Vehicle: 2012 Ram Laramie 4x4 CC
Color: White w/silver trim
Rep:63
TRCM will become famous soon enough
I ran a BHAF (huge paper air filter) on my 97 12v, and I also ran an outerwears prefilter, because the filter itself was subject to getting wet being in the open.
Never had a problem, and the outerwears kept the water out, even when the garden hose was held on it as a test.
1996 Cherokee Sport 4x4
1988 Cherokee Pioneer 4x4
Old 09-08-2012, 12:16 PM
ridgerunnerseoinc ridgerunnerseoinc is offline
Vehicle: 2010 2500
Rep:108
ridgerunnerseoinc will become famous soon enoughridgerunnerseoinc will become famous soon enough
I use them on my ATV's but not on my truck. ATV's see much harsher conditions than most trucks.
If U had a dedicated truck for off roading then maybe.
Old 09-10-2012, 03:49 AM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:64
Same here. This is the only place that I've used them and they do a good job of keeping the sand out.
2007 6.7| EFI-Live | ARP | T4 S366 | AFE | Draconian tuned TCM | Thuren
