Old 09-07-2012, 09:37 AM
chirobud chirobud is offline
Vehicle: 2010 RAM 1500 SLT
Color: inferno red
chirobud is on a distinguished road
Default Rear coil spring upgrade?
2010 Ram 1500, Reg. Cab, Short Box, 5.7
I put a leveling kit on which raised the front end 2 1/2 inches to allow for more clearance for plow undercarrige - worked well and leveled the truck . However, I'm unhappy with the load carrying capacity in the box. Heck, I throw a couple hundren pounds of feed in the back and the truck seems to squat more that it should. It's obviously worse in appearance after the leveling kit. I have a fiberglass Leer Cap on the truck.
Can you help me with what's available to siffen up the suspension on the rear. Do they make a heavier coil spring for the rear?
Buddy
Old 09-07-2012, 09:46 AM
gysnst2's Avatar
gysnst2 gysnst2 is offline
Vehicle: 2011 Dodge Ram Laramie CC 4x4
Color: Deep water blue pearl coat/Light Graystone Pearl
Rep:13
gysnst2 is on a distinguished road
Top gun customz make a heavier rear coil. I installed the 2.8 inch taller coil. The stock coil and the tgc coil are the same height but the tgc coil is a much heavier coil. Yes it lifted the rear. And I still have the same ride. But I can load the hellout of my bed.
AVS bug guard, Mopar rubber mud flaps, Mopar vent visers, Snugtop cap, Remote tailgate lock, 392 LS, VHT tail lights, 9" LCD headrests, Debaged sides, tinted 20% front 35% rear, cabin air filter mod, topguncostumz 2,25 rear lift coils, bilstein 5100 set at 2.8, and bilstein 5100 rear shocks
Old 09-07-2012, 09:55 AM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
Also take a look at two of TufTrucks Heavy Duty Coils that increase load capacity by 25% and 50%. The 50% increase rear coils are recommended to be run with a constant load and judging by you having a Leer cap, that sounds perfect for ya.
Old 09-07-2012, 09:56 AM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
SD Truck makes a rear coil for exactly what you are looking for. $125.
http://www.sdtrucksprings.com/index....ducts_id=10187
If you don't want to swap coils (which only take about 10 mins BTW) you could install Airlift 1000 bags inside the coils ($85), a Total Load control kit ($400) or Timbrens. The first two are air filled and the Timbrens are mechanical.
Old 09-11-2012, 09:36 PM
u05006 u05006 is offline
Vehicle: 2013 Dodge Ram
Color: copper head
u05006 is on a distinguished road
i have the airlift 1000 & i pull a 7500lbs trailer with a tongue weight of 850lbs & the really improved the squat.
Old 09-11-2012, 11:05 PM
Traker82's Avatar
Traker82 Traker82 is offline
Vehicle: 2014
Trim Level: Laramie Longhorn
Color: Western Saddle Brown with a Gold trim
Traker82 is on a distinguished road
Are these only for the front and do they replace the stock springs.
Old 09-13-2012, 02:22 PM
Edgethis's Avatar
Edgethis Edgethis is offline
Color: Blue
Edgethis is on a distinguished road
Are you refering to the coils or the bags?
The bags are meant for the rear and the coils are made for both front and rear IIRC.
Old 09-13-2012, 03:11 PM
Traker82's Avatar
Vehicle: 2014
I am referring to the springs. I am looking to level the front and give the rear some more strength.
Old 09-13-2012, 03:20 PM
Edgethis's Avatar
Color: Blue
Then yes, those springs replace the OEM springs.
Old 09-14-2012, 11:14 PM
gopackgo69's Avatar
gopackgo69 gopackgo69 is offline
Vehicle: 2014 Ram 1500
Rep:20
gopackgo69 is on a distinguished road
I have top gun customs springs and they ride great
2014 4x4 Hemi sport , 3.92, Pro-comp level 2.75", Rear Fox 2.0, 1.5" springs, Diablo 93 Tuned. Toyo AT2 295/65/20
