Old 09-07-2012, 03:45 PM
Maddevill Maddevill is offline
Vehicle: 2003 Dodge Ram 1500 Quad
Color: Grey
Rep:27
Maddevill is on a distinguished road
Talking One fix for a P0300 code
HI all. My 03 4.7 would periodically run rough, misfiring and stumbling at idle. it would throw a P0300 code which is "Random misfire". A forum member mentioned that the 02 sensor could cause this. So, I finally changed both upstream 02 sensors and now, a month later, absolutely no recurrence of the misfire. So, thanks again to this forum and the member who make it great.
Mad
Old 09-08-2012, 09:52 AM
Chunkem's Avatar
Chunkem Chunkem is offline
Trim Level: Longhorn Rambox
Rep:1637
Glad that you are enjoying the forum....See you on the boards,.....
Old 09-09-2012, 10:30 AM
luvmyhemi65 luvmyhemi65 is offline
Vehicle: 2004 Ram Quad Cab
luvmyhemi65 is on a distinguished road
Default Randome Missfire
I have been chasing a P0300 randome missfire on my 04 Ram for over 2 weeks. First I found a cracked spark plug in #7 and replaced all of the spark plugs and wires. The problem would disappear for a short time and then return. Yesterday I replaced the EGR valve and the problem seemed to go away. But, later yesterday, my check engine light came on with a Bank 1 O2 sensor failure. I will be replacing it shortly with a new sensor. These random misfire problems can be very ellusive as noted in these forums...Thanks for your post. SM
