Old 09-07-2012, 09:19 PM
4x4Hemi's Avatar
4x4Hemi 4x4Hemi is offline
Vehicle: 2012 Ram 1500 4x4 Hemi
Rep:172
4x4Hemi has a spectacular aura about4x4Hemi has a spectacular aura about
Default Trouble shooting ideas for why my subs don't work?
Okay so i got my subs and amp in my truck. and their just not getting any power! my amp is getting power as the light turns on, but the subs get nothing... I've checked all the wires and their all good, made sure negative to negative, and positive to positive... the RCA's hooked up right and the REM is good because obviously my amp is turning on... I can't figure it out and its really bumming me out. Any ideas??
Old 09-07-2012, 09:37 PM
johnnyG's Avatar
johnnyG johnnyG is offline
Vehicle: 2004 Dodge Ram
Trim Level: Hemi Sport
Rep:34
johnnyG is on a distinguished road
Have you tried a diff amp to start. Also check output of amp thru speaker connects with voltmeter. And sometimes you can use the wrong remote wire behind radio. Just a few things I've seen myself
SC 3865, K&N CAI, Fastman TB, Magnaflow Y to 18", sonnax, Zeon LTZs, Bilstein HDs, LEDs everywhere, sylvania ZXE heads and fogs, shorty antenna, all aftermarket audio and subs, linex, ez down tailgate and lots and lots of love.
Old 09-07-2012, 09:40 PM
MorePwr's Avatar
MorePwr MorePwr is offline
Vehicle: 2011 Ram Crew Sport
Color: Deep Water Blue Pearl Coat
Rep:50
MorePwr will become famous soon enough
Are you claiming the subs don't move at all? If so, check the signal (RCA). You will need to provide some details of how the system is setup also.
Stock headunit? Aftermarket?
Sub output?
If you are saying the subs are working, but not strong enough, then disconnect just one of them. If the remaining sub sounds stronger then you have them out of phase. reverse one set of wires to one sub.
Sean
McGaughy's|Spohn
Old 09-07-2012, 10:09 PM
4x4Hemi's Avatar
Rep:172
Ill the voltmeter thing thats not a bad idea, and the remote wire is right I'm sure. but ill look again.
The subs don't move at all. I have a different head unit so it just plugs in easier. i don't know what else to try here haha
Old 09-07-2012, 10:13 PM
I push the skinny pedal
Rep:3277
have you checked your RCA output voltage? The light just means they your remote start line is putting power to the amp. Your power wire or ground wire might not be connected properly, so also check the power wire fuse and how/where is the ground wire connected?
Kurtis
Old 09-07-2012, 10:46 PM
4x4Hemi's Avatar
Rep:172
Hmm its possible that too. I'm not even sure. i should check the output of the stereo in out on the amp first, before i check the power wire ground wire.
I think he grounded it to the battery, argh I'm not sure. next time your in edmonton you should let me know! and look at it haha
Old 09-08-2012, 05:07 PM
StoneyWV StoneyWV is offline
Vehicle: 2010 Ram Quad Cab 4X4
Rep:27
StoneyWV is on a distinguished road
If your using the sub output from an aftermarket deck, have you selected the subwoofer RCA to be active. Most of them you have to turn it ON to use it.
2010 QC ST, 5.7L, 4.10 Gear Swap, 5100 Leveling Shocks at 1.7", K&N Drop-in, Pioneer U310BT, 12" Dayton/Net Audio Sub, JL Components, ARC Audio Amps, Magnaflow 14 inch, Granite Alloys sporting 34" BFG T/A KO, HID conversion full blackout.
Old 09-08-2012, 06:40 PM
4x4Hemi's Avatar
Rep:172
I looked through all the settings on the screen and I didn't find any thing like that sadly. It's quite frustrating
Old 09-08-2012, 10:07 PM
MoparMike10's Avatar
MoparMike10 MoparMike10 is offline
Trim Level: Lone Star w/ 26L pkg
Color: Brilliant White Clearcoat
Rep:65
MoparMike10 will become famous soon enough
You seem sure that your power, ground and remote wiring are done correctly so then the culprit must be related to the signal or possibly faulty equipment. Signal problems can be as simple as a RCA that is not fully connected, or pulled loose during the installation, or it could be damaged in some way. Try using a different RCA cable and from there trying to isolate where the hiccup is.
As someone else has mentioned, its also possible that the signal to that RCA output is not enabled via the radio. You should be able to find a subwoofer menu setting that will control whether it's on or not, and maybe also things like gain/boost and phase.
A faulty amplifer most often does not turn on, or goes into protect mode and will show a light that reflects this. Not all amps, or problems with them, guarantee this. Begin by isolating each component of the sub system and you will eventually find your problem.
Audio - Pioneer AVH-P4400BH - PPI Phantom 900.4 and 1000.1 - Boston Pro 60s - Hybrid Audio Legatia L3s - 2x Image Dynamic IDQ10s
Mods - GroundForce 2/3 lowering kit - 24" Color-matched Wheels - K&N Intake - Katzkin Leather Interior
Old 09-08-2012, 10:23 PM
4x4Hemi's Avatar
Rep:172
Great advice mike
I have assured its not the RCA as I've changed it from different rcas in the head unit and then changed RCA cables. I have tried many different things and now that I have bought a multi meter, if this does not work, I will br taking it in to a shop. I know I'll get screwed on prices. But I don't know what to do. Ive already spent $400 more then what I've wanted to spend and I still don't kno what to do.
