Old 09-11-2012, 03:38 PM
cajun456 cajun456 is offline
Vehicle: 2015 Ram 1500
Trim Level: 1500 Outd Crew Cab
Color: Maximum Steel Metallic
Rep:16
cajun456 is on a distinguished road
Is this a new install or was it working then stopped? If it was working, did it just quit while playing or you turn on your truck and it not work?
Old 09-11-2012, 06:15 PM
4x4Hemi's Avatar
4x4Hemi 4x4Hemi is offline
Vehicle: 2012 Ram 1500 4x4 Hemi
Rep:172
4x4Hemi has a spectacular aura about4x4Hemi has a spectacular aura about
It was a new install, a guy i know installed it and i think i might have figured a problem... do you think this would be it??
Old 09-11-2012, 06:44 PM
Rep:3322
Ummmmmmmm........ If that's how he installed the power and ground then I would be taking it all apart and redoing, just to be sure. Wow, just wow. You definatly need to get some proper battery terminals, the crimp kind from visions will be fine, just close them with a pair of pliers or a hammer then shrink wrap them.
Old 09-11-2012, 06:53 PM
4x4Hemi's Avatar
Rep:172
Thats what ill do, i just want to get a whole new wiring kit because look at that freakin power wire... is that even metal? it feels like its cotton haha.
Is this likely the problem then?
Old 09-11-2012, 07:15 PM
Rep:3322
Looks fine, just needs to be cut, crimped, and shrunk properly. Do you know what kind of cable was used? There is quality differences in cable based on copper content and if it's tinned, vacuum shrunk, our cored. Cheap cable may claim to be 4ga but is closer to 6ga in reality.
Old 09-11-2012, 07:26 PM
4x4Hemi's Avatar
Rep:172
Uhm I think it said hyper tech or something like that? I'll check later it said on the cord what it was. I replaces the little peice from the fuse on, but now I need terminal connectors and I have some extra 4 gauge left over to. See if it works
Old 09-11-2012, 09:53 PM
MoparMike10's Avatar
MoparMike10 MoparMike10 is offline
Trim Level: Lone Star w/ 26L pkg
Color: Brilliant White Clearcoat
Rep:65
MoparMike10 will become famous soon enough
Glad you found your problem. That is one of the reasons I recommend doing it yourself, even if there are things to learn along the way. Very few people will treat your car the way you would. Cutting corners like that is not only cheap, but could be dangerous in the right situation. Update your progress, especially if you need any more help.
Audio - Pioneer AVH-P4400BH - PPI Phantom 900.4 and 1000.1 - Boston Pro 60s - Hybrid Audio Legatia L3s - 2x Image Dynamic IDQ10s
Mods - GroundForce 2/3 lowering kit - 24" Color-matched Wheels - K&N Intake - Katzkin Leather Interior
Old 09-11-2012, 10:02 PM
Rep:16
Try and ground it near the amp. You can use a seat bolt or screw into metal somewhere and the shorter the better. Also, sand any paint where the wire terminal is making contact with the metal. If you put a ring terminal on the power wire, you can put it on the terminal next to the "v" in the second picture.
Old 09-11-2012, 10:04 PM
StoneyWV StoneyWV is offline
Vehicle: 2010 Ram Quad Cab 4X4
Rep:27
StoneyWV is on a distinguished road
Wow, if you buddy did that install, then you better check the connections on the deck before you catch the truck on fire.
2010 QC ST, 5.7L, 4.10 Gear Swap, 5100 Leveling Shocks at 1.7", K&N Drop-in, Pioneer U310BT, 2/12" DC Level 3/Net Audio Sub Box, JL Components, ARC Audio Amps, Flowmaster American Thunder duals, Granite Alloys sporting 34" Falken Wildpeaks, HID conversion full blackout.
4x4Hemi's Avatar
Rep:172
Im assuming its the problem, seems like thats what would be the problem right??
Just one more question before i go out and buy terminal connectors and replace that shit power wire he has there...
Should my ground be 4 gauge as well?? because what you see connected to the battery (as a ground) is obviously not 4 gauge, and i won't be connecting it to the battery as a ground again for sure, its also spliced together
I have plenty of 4 gauge left, should i change it to that?
And i agree, i won't let anyone work on my truck like that again, really bugs me he would connect it like that. what a dink.
