Old 09-11-2012, 11:06 PM
4x4Hemi's Avatar
4x4Hemi 4x4Hemi is offline
Vehicle: 2012 Ram 1500 4x4 Hemi
Rep:172
4x4Hemi has a spectacular aura about4x4Hemi has a spectacular aura about
Originally Posted by cajun456 View Post
Try and ground it near the amp. You can use a seat bolt or screw into metal somewhere and the shorter the better. Also, sand any paint where the wire terminal is making contact with the metal. If you put a ring terminal on the power wire, you can put it on the terminal next to the "v" in the second picture.
The one with the V is where he grounded it... he grounded it to the freakin battery!! Ill ground it on the seat like you suggest !
Also the wiring on the deck is fine thanks!
cajun456 cajun456 is offline
Vehicle: 2012 Dodge Ram
Trim Level: 1500 SLT Crew Cab
Color: Deep Cherry Red
Rep:16
cajun456 is on a distinguished road
Yes, use the 4 gauge. Your power and ground should be the same size.
Old 09-11-2012, 11:16 PM
4x4Hemi's Avatar
Rep:172
Will do sir! Thanks!
Old 09-11-2012, 11:43 PM
I push the skinny pedal
Rep:3277
Yeah, same gauge in and out is a good rule of thumb. For low power systems you can get away with 4ga in 8ga out, but why potentially restrict the system when you don't have to. The seat bolt works great, and like was said earlier, make sure you have bare metal at all connection points to get a proper ground.
Kurtis
Old 09-11-2012, 11:47 PM
4x4Hemi's Avatar
Rep:172
Yeah i agree with that, plus i have about 15 feet of it so might as well haha. Pulled out his shitty ground wire he had in before and yeah... glad i took it out, its pig tailed in a couple spots, and probably LESS then 8 gauge... Replaced with 4 gauge thats only 1 foot long, going to be attached to seat bolt.
Thanks for the help guys, been extremely helpful
Old 09-12-2012, 12:10 AM
Rep:3277
Glad to be of service, we'll have to compare systems next time I'm up in Edm. I can't believe he pigtailed cable, sad really. Can I ask what the speaker-cable looking stuff in the engine bay is for? Just curious
Kurtis
Old 09-12-2012, 12:14 AM
4x4Hemi's Avatar
Rep:172
Definitely will, you coming up any time soon here??
Thats my E-cutout, i just grounded it to the battery because for some reason it wasn't working when i grounded it to the spot thats meant to ground stuff on haha
Old 11-13-2012, 09:11 AM
otturious's Avatar
otturious otturious is offline
Vehicle: 2007
Color: Grey
otturious is on a distinguished road
You have your power wire running through the same plastic plate on the firewall as I do. You may want to consider putting a sealant around it or a grommet. It didnt occur to me to do it till I was scrubbing down my engine with simple green. I went to grab my phone out of my cab and had water running out the bottom of the door. No real biggy to me cause I dont have carpet. Just a helpful fyi.
Old 11-13-2012, 12:57 PM
4x4Hemi's Avatar
Rep:172
aahh yeah i was thinking about that when i cut it. Im selling my subs here soon, so ill just tape it off or something
Old 11-27-2012, 03:06 PM
Thebestestdrummer's Avatar
Vehicle: 2001 Dodge Ram Sport
Rep:529
I would first go ahead and try the 9 volt battery test. Take a 9 volt battery, buy a alligator clip to 9volt. I think radio shack has some. Clip the to the positives and negative, and you should hear a pop. If not then your sub might be blown. Or try borrowing sub from a friend and hook the up, if it works then something's wrong with your sub.
Air horn "AHHOOOGA" horn,
Green Interior LEDs
