Front wheels wont engage - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram 4x4 - Offroad Discussion
Old 08-27-2012, 04:17 PM
sth7344 sth7344 is offline
Vehicle: 1999 Dodge Ram 1500 sport
sth7344 is on a distinguished road
Default Front wheels wont engage
I have a 99 Ram Sport 1/2ton. The other day i went to go play in the mud and when i got onto the trail i shifted into 4h and the light on the dash did not come on and i found that my front wheels were not engaging. I wanted to make sure it wasnt the transfer case so i shifted into 4L and the low works but the front wheels still wont engage and the light still wont come on in the dash. Any ideas?
Old 08-27-2012, 07:19 PM
I found what looks to be a metal vacuum line that runs from the actuator on the back of the front axel to the transfer case that is broke. Could that be the culprit?
Old 08-27-2012, 07:24 PM
TRCM's Avatar
TRCM TRCM is offline
Vehicle: 2012 Ram Laramie 4x4 CC
Color: White w/silver trim
Rep:63
TRCM will become famous soon enough
That IS the culprit.
Had the same thing happen on my 97 ctd 4x4 dually. 4wd stopped working on my way out of a particularly nasty trail on the hunting property. I managed to claw my way out by putting it in 3rd gear and just letting the dual rear wheels eat.
When I got back on solid ground, I looked and the vacuum line had come off at the tcase. Put it back on, and voila, 4wd worked again.
1996 Cherokee Sport 4x4
1988 Cherokee Pioneer 4x4
Old 08-27-2012, 10:02 PM
The only problem is that it broke the metal line rite next to the cat. Not sure how im gonna spilce it back together
Old 08-28-2012, 03:40 PM
I fixed the broken line and tried it again. Still nothing. Found that i have no vacuum coming from the T-case. Ive looked all over for leaks and more broken lines and cant find anything. Bad switch in the T-case?
Old 09-15-2012, 01:48 AM
Ramboi92's Avatar
Ramboi92 Ramboi92 is offline
Vehicle: 1995 Dodge Ram 1500
Trim Level: Laramie SLT
Color: Pearl Emerald Green
Rep:13
Ramboi92 is on a distinguished road
I would suggest taking a look at a vacuum line behind your passenger wheel near the coil. My 4wd wasn't engaging one day and I noticed the line had broke.
Nitto Trail Grapplers wrapped around 18" Mamba M3's. They'll take me anywhere. In 2wd.
Old 09-15-2012, 03:43 PM
TRCM's Avatar
Rep:63
Either a bad switch in the tcase, or a leak in the vac line to the tcase.
