Old 09-08-2012, 11:57 PM
jabradley jabradley is offline
Vehicle: 2012 ram 1500
jabradley is on a distinguished road
Default Question on 295/60/20 terra
I have a 2012 sport 4x4 and had a 2 inch leveling kit put on today. I would like to put Nitto terra grapplers 295-60-20 on it. I realize I will probably have to go with a 1/4 inch spacer to help offset. Is anyone running these tires with stock 20 inch wheels?
Old 09-11-2012, 11:13 PM
TNhemi12 TNhemi12 is offline
Vehicle: 2012 Dodge Ram
Color: Mineral Gray
Rep:18
TNhemi12 is on a distinguished road
Want to run the same tire on aftermarket wheels with a +1 offset and 2.5" leveling kit, will they work with no rub?
Old 09-12-2012, 06:07 AM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:64
I don't have that set-up and hopefully someone that does will chime in for you. You shouldn't have any problems with the set-up that you plan to go with though.
Can't tell you without knowing the wheel width.
2007 6.7| EFI-Live | ARP | T4 S366 | AFE | Draconian tuned TCM
Old 09-13-2012, 01:42 AM
RyanJM's Avatar
RyanJM RyanJM is offline
Vehicle: 2014 Ram 1500
Trim Level: Express RC
Color: Black Express Package
Rep:67
Should be fine with a +1 since I have 285/60's with a +13 and no rubbing. The 12mm difference if offset should make up for the extra width of the tire. I know with the +13 and 305/55's I only got rub at full lock. Hopefully that helps.
Also mine is only a 2wd with 1.5 level up front
Old 10-04-2012, 02:05 PM
davidlonghorn's Avatar
davidlonghorn davidlonghorn is offline
Vehicle: 2012 Dodge Ram 1500 Longhorn
Trim Level: Laramie Longhorn
davidlonghorn is on a distinguished road
You might not need the spacer but if you do don't get anything more then 1/4". What I did is when I got mine I had the dealer put the tires on and checked clearance before adding the spacers but I did have to since I went with 295/55 R20 Nitto Trail Grapplers and they were rubbing on the tread on the back of the tire not the tire itself. Here is a pic with the tires more in profile.
2012 Laramie Longhorn 4X4 5.7L Hemi
295/55 R20 Nitto Trail Grapplers Performex 2.5" Level
Old 10-04-2012, 02:07 PM
Colorado700R's Avatar
Colorado700R Colorado700R is offline
Vehicle: 2011 Ram 1500 Crew 4x4(Rambox)
Rep:34
Colorado700R is on a distinguished road
Nice looking ride Bro. Gas mileage, or towing noticably diffrent with the leveling and tire size?
Aaron
Old 10-04-2012, 02:36 PM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
I agree that it certainly doesn't hurt to check fitment before just bolting up the spacers but I almost guarantee you will need them. The general rule is anything wider than 285 on stock rims will require them.
