Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 09-09-2012, 01:12 AM
sbunker1's Avatar
sbunker1 sbunker1 is offline
Vehicle: 2006 Dodge Ram 1500
Color: Grey
sbunker1 is on a distinguished road
Default 2006 Ram 1500 sport crew cab Ball joints
I have been having suspected problems with front end. Found out today that both lower ball joints were popped. I am going to replace the myself, but I the the auto parts stores dont have a clue. What the hell is an extended crew cab? they have different pt numbers for crew vs. extended crew. I dont want to get everything apart and not have parts to put ity back together. I also thought that if I was replacing the lowers...I should replace the uppers also...does that make sense?
Thanks.
Old 09-09-2012, 07:13 PM
99gp's Avatar
99gp 99gp is offline
Trim Level: SLT Sport
Rep:155
The extended crew cab is the mega cab I think. 2006 was the 1st year they had that. From the little picture I would say it is a crew cab not a mega one (extended crew cab). Here is the mega cab
And here is the crew cab
Also when I replaced my ball joints a couple months ago, I only did lowers because of lack of funds. But doing all 4 if you can afford it definatly won't hurt anything except your pocket. I would also make sure you get a good quality ball joint like moog that is grease-able. If you need help I wrote a step by step process (kinda) of how to do them.
Old 09-09-2012, 07:31 PM
sbunker1's Avatar
Color: Grey
I have all 4 ball joints. As much as i tried, i could not separate the Tie rod. I loosend the nuts on both ball joints and was able to get the top on to move as far as the nut was loosened, but I couldnt get the lower one to pop at all.
Old 09-09-2012, 07:35 PM
99gp's Avatar
Rep:155
did you happen to look at my post? You will either need a pickle fork (didn't work for me), or the tool that I posted in here http://www.ramforumz.com/showthread.php?t=117742
Old 09-09-2012, 07:44 PM
sbunker1's Avatar
Color: Grey
I just did. I feel dumb now. I have a puller set and didnt even think of using it. I could just use a socket since a regular puller doesnt have a swivel on the end of the screw.
Old 09-09-2012, 07:52 PM
99gp's Avatar
Rep:155
Hey don't feel dumb. I was smashing my head against the wall trying to figure out how to break my lower ones lose. I ended up having to rent a front end kit from auto parts store just to get the puller. If you need any more help just ask and good luck on the project
Old 09-09-2012, 07:59 PM
sbunker1's Avatar
Color: Grey
thanks, I put it back together and will try again tomorrow.
Old 09-09-2012, 08:08 PM
99gp's Avatar
Rep:155
what ball joints did you happen to get?
Old 09-09-2012, 08:12 PM
sbunker1's Avatar
Color: Grey
I got the moog. Lowers about $68 ea. Uppers about $80 ea. I may have been able to find cheaper online, but I wanted to go pick them up incase there are any problems and I need to return or exchange.
Old 09-09-2012, 08:42 PM
99gp's Avatar
Rep:155
That isn't bad. I think that is about what I paid for my lowers (haven't done uppers yet). Glad to see you got a good brand
