Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Towing
Place your Ad Here!
Old 09-09-2012, 02:09 AM
rjg12 rjg12 is offline
Vehicle: 2014 Ram 1500 Black
Trim Level: Black Edition
rjg12 is on a distinguished road
Default brake controller activation
just wondering if there was any way to activate mopar brake controller after instal without going to dealer and getting charged for it
Old 09-09-2012, 02:24 AM
Rep:2910
You have the Express
did it come with the Brake Controller ?
If you added it, likely you have the bare bones instrument panel
in that case, the dealer can't help you
If your Express has the Full EVIC, ( fancy name for Instrument Panel )
then the dealer can Flash your computer & make everything work
Old 09-09-2012, 02:46 AM
Default yes it has both harnesses
I guess some of the rams only have one harness which means going aftermarket but I was the lucky one and have both. Thanks
Old 09-09-2012, 02:54 AM
Rep:2910
a full EVIC looks like this
Old 09-09-2012, 09:57 AM
davidgcet davidgcet is offline
Vehicle: 2012 Ram 1500
Trim Level: Outdoorsman
Rep:32
davidgcet is on a distinguished road
my understanding is the controller will work just fine without being flashed in, but it just won't show up in the EVIC???
Old 09-12-2012, 11:38 PM
spymac's Avatar
spymac spymac is offline
Vehicle: 2011 Ram 1500
Color: Deep Water Blue Pearl
Rep:41
spymac is on a distinguished road
From the research I have done on the 2011, the controller will work if you have both connectors under the dash. However, you will be missing a number of features:
-Choosing between Light and Heavy brakes, which seems like it is a form of automatic gain adjustment.
-EVIC display messages and feedback.
This member has one that he installed after the fact and says it works fine.
http://www.ramforumz.com/showpost.ph...8&postcount=36
Hopefully in the next month I will be picking one of these up. Its only about $100 and I've wasted enough time researching it and finding no solid answers. I'm going to try it and if it doesn't work, re-sell it.
Old 09-16-2012, 02:22 PM
organized mayhem organized mayhem is offline
Vehicle: 2016 Ram 3500
Trim Level: Laramie Mega
Color: Luxury Brown Pearlcoat
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 350hp 660lb/ft (6-Speed Manual)
organized mayhem is on a distinguished road
Yes it will work just fine without an EVIC. I had both plugs and installed a factory unit in my Express. The dealer is only needed if you want to program it into the EVIC if you have one.
Old 10-18-2012, 02:17 AM
blk2011st blk2011st is offline
Vehicle: 2011 Ram
blk2011st is on a distinguished road
No. They have to add the sales code for it to show up on the EVIC, but it will still work without adding it. Mine works great and i dont have EVIC. Its a pretty smart controller for being oem.
Old 10-22-2012, 08:12 PM
Evanrude's Avatar
Evanrude Evanrude is offline
Vehicle: 2012 RAM 1500
Trim Level: SLT w/Big Horn pkg
Color: Mineral Gray
Rep:14
Evanrude is on a distinguished road
I was going to post a new question, but noticed this thread going. I hope the OP doesn't mind...
I added the controller to my truck about a month ago - not flashed yet. Today, I finally hooked up to a trailer with brakes. I didn't seem to have any brakes. Its not my trailer, so I'm not even sure if the brakes work. I will ask the owner tomorrow.
My question is, has anyone added fuses to the fuse box? I've tried to research the M4 fuse but haven't had any luck. Who here has actually used a braked trailer and can confirm that it works without a flash and adding fuses?
Old 10-23-2012, 04:38 AM
Vehicle: 2011 Ram
I have not added any fuses and mine works great. I have a 18ft big tex car hauler that i pull around once and a while, and i can confirm that the brakes work.
