Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > 2012 Dodge Ram Forum
Old 09-09-2012, 12:20 PM
Asur Asur is offline
Vehicle: .
Rep:4373
Originally Posted by Bikenut View Post
Boats are inherently set up well on their trailer. Other than cross wind, boats tow very well. Make sure your bearings are lubed well for the trip and tires are worthy and you will be totally fine.
Very good point, get your bearings checked at the same time you get your break line repaired.
borodin1 borodin1 is offline
Vehicle: 2012 Ram 1500 QuadCab Sport
Trim Level: Quad Cab Sport 4X4
Rep:14
borodin1 is on a distinguished road
Talk to the people your getting your boat from and get more information about how they usually tow that unit.
Probably won't do me any good...they towed it for less then a mile at the time with some dinky Explorer.
Old 09-09-2012, 12:47 PM
rdsabin rdsabin is offline
Vehicle: 2012 Sport Reg Cab 4x4
Trim Level: Sport Reg Cab
Color: Mineral Gray Metallic
Rep:186
rdsabin has a spectacular aura aboutrdsabin has a spectacular aura about
Just go get a weight distribution hitch and have them set it up for your boat and you should be good to go. Don't tow in overdrive, use the tow/haul button. I assume you have a brake controller in your truck, if not get one and have it adjusted to the trailer loaded. Any reputable hitch dealer can fix you up and get you on your way. Make sure you have a spare for the trailer also as not all flats are repairable.
Good luck on your trip.
2012 DodgeRam 1500 4x4, 20% Tint, Running Boards, Class IV Hitch, 14" Win Muffler, Catch-Can, Tow-Hooks, LED Tailgate Bar
2008 Dodge Supe Bee, Catch Can, Backup Camera, 20% Tint all windows, CAI, AFE Filter
Old 09-09-2012, 12:53 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PXR Black
Rep:2477
Smile
Originally Posted by borodin1 View Post
This is similar boat. I'm towing a 25' Chris Craft and I wouldn't think twice if it was 200km (150mi) but we're talking 1100 miles here, that's quite a distance. And I am thinking of taking a frequent breaks to make sure temps are in check. I am planning on taking the thing to the shop to grease the bearings and make sure tires are going to hold up. I know that trailer has surge brakes and one of the brake lines is leaking so I'm planning to repair that as well before leaving. Gonna take a full set of tools with me along with some tire repair kits and portable compressor. Should be ok.... right?
Excellent idea in getting all those repairs done first, I'd say they are essential. Frequent breaks are also a good idea. I had mine in tow/haul the whole way and had my temps up on the EVIC as well. For me, my average speed was between 80 and 90 km/hr while towing. The temperatures while towing were as follows, 69C (156F) trans, 99C (210F) oil and 97C (206F) coolant.
Old 09-09-2012, 01:35 PM
scarolina360's Avatar
scarolina360 scarolina360 is offline
Vehicle: 2012 Dodge Ram 1500
Color: Sooner Boomer Red
scarolina360 is on a distinguished road
The weight distribution hitch is awesome! I towed around 10,000 lbs behind my truck with a weight distribution hitch from upstate New York to lower North Carolina with absolutely no issues. I ran 70 pretty much the whole way, even through the mountains, just fine.
Old 09-09-2012, 01:42 PM
Vehicle: .
Rep:4373
Sorry, was not mentioned in your original post, just trying to help
Old 09-09-2012, 04:30 PM
Rep:14
ALL suggestions are appreciated so thank you.
Well, looks like I'm not towing anything at this point. Seller backed out of the deal as soon as he heard I will be coming in person to pick it up
It's true what they say, if it's too good to be true - it probably is.
Thank you all for your input on this, it will definitely come in handy at later date.
Keep on trucking!
Old 09-09-2012, 05:04 PM
titanman2789 titanman2789 is offline
Vehicle: 2012 Ram 2500 4x4
Rep:40
titanman2789 is on a distinguished road
You will be fine. With 1500 miles on my truck I towed 1000 miles. Granted, it was a dinky Uhaul trailer (5'x8') BUT I did have a ton of stuff in it and piled the bed and cab full of people/dog/stuff.
You'll probably want airbags as suggested already.
The truck should be fine on the temps. Just watch the gauges. You shouldn't HAVE to make stops just to let it cool down. It's a truck, it was made to be worked.
One thing I will add though, if you haven't done it yet, change your oil first.
AAAaaaand just read your last post. That sucks, but hey, better than driving out there first I guess
Old 09-13-2012, 01:40 PM
evanyj350's Avatar
evanyj350 evanyj350 is offline
Vehicle: 2016 2500 6.4L CC Air Susp
Trim Level: Laramie Longhorn
Color: Black/Gold
evanyj350 is on a distinguished road
In another post, a guy said he kept it in 4th gear for the trip. Engine revved a bit higher, but hunted less and got better mileage. 5th and 6th are overdrive gears.....
Sounds like air bags will help a lot with stance of truck and headlight aim...
'12 1500 CC Black/Gold L L - ( retired/traded Jan '16)
2016 2500 CC 6.4 Black/Gold Lar Long w/ Rr Air Sus
Old 09-17-2012, 08:50 AM
Rep:14
Well, what do you know, I did end up going and picking this boat up.
2 days, 8 states, 2300 miles and 170 gallons of gas later I'm home with the boat
I must say Ram performed above my expectations. I had no problem whatsoever pulling such a big rig and even got 11mpg loaded (23mpg empty). Here's couple of pics...
Once again, thank you for all your suggestions
hauling, safety, towing capacity
