Running terribly throwing some codes. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 09-09-2012, 12:45 PM
2hellwithhybrids 2hellwithhybrids is offline
Vehicle: 2003 ram 1500 4.7
2hellwithhybrids is on a distinguished road
Default Running terribly throwing some codes.
Hey all,
I'm troubleshooting an issue on my brother in law's truck. He brought it over the other day, said it was running like crap and the check engine light was on. I scanned it and pulled the following codes:
P0442 - EVAP emission control system leak
P0305 - cylinder 5 misfire detected
P0141 - O2 sensor heater circuit malfunction (bank 1 sensor 2)
Truck is an 03 1500 4.7L with 103k miles. I'm thinking o2 sensors but wanted to double check with some experts before shotgunning parts. Any info would be much appreciated.
Thanks!
-Shawn-
Old 09-20-2012, 03:46 PM
OffRoadRam25's Avatar
OffRoadRam25 OffRoadRam25 is offline
Vehicle: 03 Ram Off Road QC 4x4
Color: Blue
OffRoadRam25 is on a distinguished road
I would start with o2 and plugs, clear the codes and see if anything else pops up later.
*Off Road ed.,Bully Step bars,tow mirrors,leveled,315/70/17 BFG,rebuilt 4.7L,10k HIDs,Blue int leds*
Old 09-20-2012, 04:49 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Could be gas cap(look for dry rotted/broken seal around cap. Could be leak anywhere in the EVAP system(look around the EVAP canister for dry rotted hoses, etc.
Could be a plug, coil, pcm...lots of things...
Could be the sensor itself. Could be a damaged wire. Not sure if it could be the catalytic converter. Sensor 2 is after the catalytic converter. I don't remember if bank 1 is driver or passenger side.
I'd also start by replacing plugs/wires(not sure if that engine has plug wires). Clear codes and see what comes back. Also could disconnect the pcm for 15 min and hold brake pedal for 20 seconds to reset the pcm. Then see what codes come back. The misfire is causing the rough running. EVAP and the downstream O2 have basically no effect, just emissions. Still would be nice to fix them though(especially if it's easy).
Sean
Old 09-20-2012, 05:03 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:627
great starting points given.
and bank 1 is drivers side.
Old 09-21-2012, 08:41 PM
DodgieDan DodgieDan is offline
Vehicle: 2009 Ram 1500 Quad Cab Hemi
Color: Inferno Red
DodgieDan is on a distinguished road
Could be the plugs causing the miss fire as well as each cylinder has its own individual coil. If plugs do not solve the problem try switching the coils with another cylinder. If you get the same message on the cylinder you switched it to you will know it is the coil. No plug wires persay it is all part of a wiring harness and quite expensive to switch.
As far as the O2 sensor goes try one and if it goes away you have solved the problem.
As far as the Evap goes gas cap loose or gasket gone.
