Old 09-09-2012, 02:46 PM
dirtsforracin dirtsforracin is offline
Vehicle: 2012 dodge ram sport 1500 4wd
dirtsforracin is on a distinguished road
Default 4x4 lowering kit
I'm a T 2 parapalegic with 2012 ram 1500 sport, due to som medical issues i'm needing to drop it another 2-3 inches, any sugestions?
Old 09-09-2012, 03:08 PM
Captain Cooter Captain Cooter is offline
Vehicle: 2012 Ram Sport Reg Cab 4x4
Color: Flamin red
Captain Cooter is on a distinguished road
Do a google search for Ground Force 4x4 Lowering Kit part # 9984. There's quite a bit of information out there, I'm looking at a how-to guide from a different forum. I'd post a link but I don't know the rules about this place, seeing as they try to make money off this forum.
Old 09-10-2012, 05:14 AM
oldhp's Avatar
oldhp oldhp is offline
Vehicle: 2014 Express 3.6/8 speed auto
Color: WHITE
Rep:902
oldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to behold
I don't know where you would get it, but a air bag system that replaces the coil springs would allow even more drop. As suggested above, Google or start looking in custom truck magazines for venders. Who knows maybe one of them that you contact will start a system for you. I have faith that somebody will help you out!
Good Luck!!!
oldhp
2014 Express 3.6/8 speed/3.55 gears...Work Truck
2012 Equinox 2.4...Wife's Ride
"Life's hard, it's harder if your stupid."
How would you know?
Old 09-10-2012, 09:17 AM
Asur Asur is offline
Vehicle: .
Rep:4371
Definitely I would look at lowering air bags, then when your driving you can bring up the height.
Look at places like this to find a kit that will work for you:
http://www.autoanything.com/suspensi...A23A224A1.aspx
http://www.airbagit.com/
http://www.arnottairsuspension.com/
http://air-ride-equipped.com/
Old 09-10-2012, 08:43 PM
I push the skinny pedal
Rep:3277
You are actually in an area with several people running lowered 4x4s reliably. The ground force 2/3 kit will get you started, if you need to get lower then rear air bags help. The front is where you have the most trouble with a 4x4 because you can have severe angles on the cv joints. You can cut a spring section off and get realigned, our you can do 2"drop spindles, but spindles will require heavier duty half-shafts.
Kurtis
