Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Brakes
Brakes Brake Maintenance and Replacement
Old 09-10-2012, 07:14 PM
metalmech's Avatar
metalmech metalmech is offline
Vehicle: 2005 Ram Quad
Color: dark grey metallic
metalmech is on a distinguished road
Default Brake rotors
I need to replace the rotors on my 05 ram. Thinking about cross drilled/ slotted or dimpled/ slotted. What do u think?
Old 09-10-2012, 07:33 PM
CdnoilRAM CdnoilRAM is online now
I push the skinny pedal
Rep:3277
Ideally, neither. Cross-drilled and dimpled is just for aesthetics these days, you also can't turn them, sup if they warp then you are replacing rotors instead. Only porche actually runs cross-drilled from the factory and then only on one vehicle. if you want the looks, then go for it, if you want performance then get a set of smooth or slotted rotors.
Kurtis
Old 09-10-2012, 09:26 PM
UNBROKEN's Avatar
UNBROKEN UNBROKEN is offline
Vehicle: 2012 Ram R/T
Trim Level: R/T
Rep:123
UNBROKEN will become famous soon enoughUNBROKEN will become famous soon enough
Many OEM's besides Porsche still run drilled rotors on high end cars....just sayin'
Are they necessary on our trucks? No
Do they look cool as hell? Yup
Run em if you like em but don't expect any real reduction in stopping distance from them.
Old 09-11-2012, 05:07 AM
KarateManAZ's Avatar
KarateManAZ KarateManAZ is offline
Vehicle: 2009 Dodge Ram
Trim Level: MagnaHEMI
Color: Deep Water Pearl Blue
Rep:120
KarateManAZ will become famous soon enoughKarateManAZ will become famous soon enough
I have the slotted/dimpled EBC rotors along with the yellow stuff pads. A great combo!
2009 Ram 1500 Crew Cab - Deep Water Pearl Blue
2/4 Drop, 0212353 Retro Shop Projector Retrofit w/ custom paint, Jet 180 T-Stat, AR LT Headers, 545rfe w/ deep pan,
Inertia Cam, Edge Triple Disk, Magnaflow 18"
Oh Yeah its a MagnaHEMI 12.2@109
Old 09-11-2012, 06:24 AM
hodgeee's Avatar
hodgeee hodgeee is offline
Vehicle: 2012 dodge ram 1500 2x4
Trim Level: express
Rep:134
hodgeee will become famous soon enoughhodgeee will become famous soon enough
I would have to argue that dimpled make a difference from reviews I have read.
The EBC dimpled gold rotors and ceramic pads are actually designed to work specifically with eachother, and are a stronger brake package then stock. The rotors are coated with a superthin layer of harder substance wich grabs ceramic padded materiel like crazy, but it is so much harder than the ceramic, according to EBC and myself, from installing them on a girlfriends car, the rotor doesn't wear at all, it is all in the pad, since the coating is said to last the life of 2 full sets of pads from EBC. I installed these on her 2004 Tiburon, and then 48,000 miles later put a new set of pads on them, and I never touched the rotors, they looked completely unworn.
BellTech 2/4 Street Performer, Spohn PanhandRod, Hellwig Sways, Volant Intake(Donaldson Filter), 85MM Fastman Throttle body, 14" Magnaflow, T1000 w/Hemifever Tune, 180 T-stat, 4.10 Gear Swap, Edge Street Perf - 2600 Stall, Billet Catch Can, E-Fan Swap, ARH LongTubes
