TufTruck TTC 1223 - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 06-17-2014, 05:02 PM
416Hemi 416Hemi is offline
Vehicle: 2013 Dodge Ram Sport CC
416Hemi is on a distinguished road
Did you change the shocks in the rear or are you using factory shocks still? I'm looking to upgrade to these as well as I tow up to 7000lbs too and the factory springs are garbage.
Have you towed a trailer since installing? Can you give any feedback? On the website it says they are best for trucks that are constantly loaded, how bad is the ride when empty?
Old 06-17-2014, 05:08 PM
bstc00's Avatar
bstc00 bstc00 is offline
Vehicle: 2009 Ram 1500
Color: Inferno Red
Rep:224
bstc00 has a spectacular aura aboutbstc00 has a spectacular aura aboutbstc00 has a spectacular aura about
I changed the shocks out later on. If you get the ones that I have you will notice a stiffer ride. I us my truck for towing and have a 20x8.5 enclosed cargo trailer on my truck all the time with up words of 930 lbs total. On my lighter loads you can't really see any sag on the truck but with bigger loads you can. I have said it before and I'll say it again. The truck should have come with something like these from the factory.
Old 07-14-2014, 04:24 PM
Dpown Dpown is offline
Vehicle: 2012 Dodge Ram
Dpown is on a distinguished road
You should get their variable model if your truck wont be under a constant load. http://tuftruck.com/products/dodge/TTC-1223V.html They do a similar job but are designed for the more casual user.
Old 07-17-2014, 12:28 AM
audio1der audio1der is offline
Color: Dark Red Cherry
Rep:201
audio1der has a spectacular aura aboutaudio1der has a spectacular aura aboutaudio1der has a spectacular aura about
A friend of mine installed the 1223's and says he can barely tell a difference in ride quality when empty, but doesn't need to rely on his Airlift 1000's anymore.
I'm leaning towards the 1223 as I want to cut them to lower 2" to match my current stance, and you can't do that with the 1223V.
'12 Ram 1500 4x4 Sport CC;Airlift 1000, Moroso air/oil can, S&B CAI & scoop, 87mm P/KE/P/TB, Jet 180, Magnaflow
Old 07-17-2014, 10:43 AM
I can see why you want that, but have you thought of contacting them? I was fairly sure I saw on their website that they can make special orders - maybe you'll be able to get something for the best of both worlds?
Old 01-25-2016, 06:42 PM
Hemi-1340 Hemi-1340 is offline
Vehicle: 2016 Ram 1500 5.7 Hemi
Trim Level: Outdoorsman
Color: Charcoal Gray
Hemi-1340 is on a distinguished road
Did these raise your rear end any? On their website says it will but some say it doesn't raise it much any input ? Thanks
Old 02-11-2016, 10:47 PM
gofishn's Avatar
gofishn gofishn is offline
Vehicle: 2014 Ran 1500 Crew Cab 4X4
Color: Deep Cherry
Rep:183
gofishn has a spectacular aura aboutgofishn has a spectacular aura about
Call TufTruck and ask them. I did, just a few days ago. Fella said he designed the 1223 and they are intended for minimum 500-600lb loads, at all times. when not under load will raise the truck 2-4 inches. Seems the weight of the truck, on the OEM springs drops the spring alot more than the weight of the truck on the TTC-1223 Spring.
IF desiring same height, than go with the TTC-1211. Same 50% increase in load rating (additional 900lbs is what he told me) but same ride height as OEM, once under the truck.
Husky X-ACT Mats, AVS Deflectors, DZ Tailgate Assist-Bed Mat, ARE Cap, Line-X, OEM Remote Start-Mud Flaps-W2W SS Steps, Kenwood DDX492, Alpine MRV-F300 Amp&SPR-6x9's, Polk DB351, Stinger Roadkill, Bilstein 5100@2.1, TufTruck 1211 Springs, Mevotech UCA's, Magnaflow 12388 Exhaust, Fold Flat Floor
Old 03-06-2016, 11:45 PM
Valkraider Valkraider is offline
Vehicle: 2015 Ecodiesel 1500
Trim Level: Tradesman
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
Valkraider is on a distinguished road
TufTruck TTC-1223 Rear Extra Heavy Duty Coil Springs
(Not the variable rate ones - these are intended for a constant load - like my camper that stays on)
Unloaded gives a 1.5 inch lift. Loaded with 800lb is exactly the same as stock.
