Cruise Control Lights, but doesn't work - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Old 09-12-2012, 04:33 PM
Goobz Goobz is offline
Vehicle: 1998 Dodge Ram 1500
Trim Level: Laramie SLT
Goobz is on a distinguished road
Send a message via ICQ to Goobz Send a message via AIM to Goobz Send a message via MSN to Goobz Send a message via Yahoo to Goobz
Default Cruise Control Lights, but doesn't work
Hey all..
Just purchased a `98 1500 5.2L. When trying to use CC, when I hit the button on the steering wheel, the dashboard lights up. However, it will never let me 'set' cruise. Any ideas?
Old 09-12-2012, 05:24 PM
Phatninja55's Avatar
Phatninja55 Phatninja55 is offline
Vehicle: 1994 Dodge Ram 1500 Reg. Cab
Phatninja55 is on a distinguished road
Originally Posted by Goobz View Post
Hey all..
Might be a vacuum problem. Not sure tho. Could be the abs speed sensor. But i'm not really sure. My cruse light doesn't come on at all. the abs light and brake light is on.
Old 09-20-2012, 03:42 PM
toprjf739 toprjf739 is offline
Vehicle: 1997 Dodge Ram 1500
toprjf739 is on a distinguished road
probably a broken vacuum line, happened to me. there is a very thin vacuum line that runs from the passenger side of the engine right near the rear side of the fuel injector rail and crosses over the front of the engine and connects to the cruise control servo which is located under the battery. Mine broke under the batt box so I did not see it
Old 09-20-2012, 09:01 PM
I try to set the cruse control on, but the light doesn't come on. I've replaced the abs speed sensor. That didn't fix it. The abs light, and brake light is on. Any suggestions. The parking brake doesn't work at all, could this be related in any way? TIA.
Old 10-06-2012, 02:45 AM
slimpartywagon's Avatar
slimpartywagon slimpartywagon is offline
Vehicle: 1995 Dodge Ram 1500, 2000 Ram
Trim Level: Laramie, SLT
Color: Blue
Rep:95
slimpartywagon will become famous soon enough
my light doesn't come on, but the cc does work... it didn't work at first, but as Phatninja55 said, I had a broken vacuum line in the exact same spot. repaired the line and it works... just need to replace the bulb in my dash now.
Old 10-06-2012, 09:14 AM
I just want to fix this credit mix up, Credit for the find should go to toprjf739 He's the one who told you to look at the line.
Old 10-14-2012, 01:04 AM
Color: Blue
Rep:95
Actually I found it all on my own... I checked the fuse first.. then I went to the throttle linkage and traced it back to the Vacuum actuator motor for the CC, then saw the broken vacuum line coming out of the canister.
Old 10-21-2012, 04:17 PM
Thanks all! It was a broken vacuum line. However... I can't really tell where the vacuum line connects to the servo. A buddy has a `00 Dodge Ram, and it's a different servo, and I can't find a service manual for a `98. Anyone have any pics or manual as to where the vacuum line would connect!?
cruise control, dashboard, speed
