Old 09-13-2012, 09:24 PM
281countryboy 281countryboy is offline
Vehicle: 1998 laramine slt 2wd 1500 2wd
Trim Level: laramine slt
Color: red
281countryboy is on a distinguished road
Default drive shaft questions
so i think i have traced the noise to the drive shaft where the u joints are . am i supppose to be able to rock it side to side and hear a clinging noise and should it have oil on it because i can rock it with out it turning the tires and it has a dark bit of oil on it up coming from the tranny end yet the tranny is clean ????????
Old 09-13-2012, 10:02 PM
Dodge Boy13's Avatar
Dodge Boy13 Dodge Boy13 is offline
Vehicle: 1998 Dodge Ram 1500
Trim Level: sport
Rep:23
Dodge Boy13 is on a distinguished road
you u joints will throw some grease but im not sure about the rocking i dont think that should do that it should be pretty tight
My Build Thread!!
http://www.ramforumz.com/showthread.php?t=118514
Old 09-15-2012, 10:37 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
(Thinking I wish I knew where my book is...) does this driveshaft have a simple ujoint at each end, or a fancy double jointed thing at one end? (otherwise known as a double cardan joint) and if so, is this where the slop is coming from? is this a std cab shortbed, or 4 door longbox, or what kind of body style? Does it have a carrier bearing in the driveshaft?
