Old 09-14-2012, 11:53 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
because of my mods, none of my piping is less than 3"...I've seen others locally do the identical setup but use smaller piping..
Old 09-14-2012, 11:55 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
There are several ways to go about a good exhaust setup. I'd do a Y pipe with single exhaust, or split tail pipes if you want the dual look. There's really not much gain with "true duals". It'll save you a ton of money too(especially with SS....get ready to be shocked with $$ when you go in). Or you could do something like fred did.
If doing duals all the way, definitely have either an x or h pipe crossover. Also if you don't plan on heads or cam then probably stay at 2.25" pipes. 2.5" wouldn't be too bad though. 3" duals would probably be too big and cause power lose that's noticeable.
If single, do either 2.25" or 2.5" duals to a single 3".
Sean
Old 09-14-2012, 12:31 PM
DOZER's Avatar
DOZER DOZER is offline
Vehicle: 2006 Ram 2500 Quad cab 4x4
Color: Atlantic Blue
Rep:140
DOZER will become famous soon enoughDOZER will become famous soon enough
Send a message via Yahoo to DOZER Send a message via Skype™ to DOZER
if your state doesn't do inspections..delete the cats as well... if I did true duals, I would do 2.5" pipes after muffler... I'll throw the monkey wrench in..consider true duals to muffler, an H instead of X (for tq)...then take a single in/dual out maggie and rotate 180 degrees...and, at your option, add cutouts..
My state does yearly inspections that include a probe up the tail pipe. What will rotating it 180 do?
'06 2500 ST 4x4 Quad cab, Vararam CAI, Bed/Hood stripes, Vent visors, Bully tailgate lock, Moto Metal 909 18x9, Nitto Terra Grapplers 295/70/18 HBS 2" level, Bilstein 5100's, Bushwhacker flares, 5000K HID's, Diablo Trinity 87 tune, LineX, Bakflip F1.
Old 09-14-2012, 12:36 PM
snrusnak's Avatar
Rep:1385
He took a single in dual out muffler and reversed it so it was a dual in single out muffler. Straight through mufflers are reversible. So basically his y pipe is in the muffler, and he has an h pipe before the muffler.
Sean
Old 09-14-2012, 12:37 PM
DOZER's Avatar
Rep:140
The headers come with a 3" Y pipe So I guess it will keep it and do a SIDO muffler. Now the question is which muffler? Magnaflow 14", Magnaflow glass pack or cherry bomb. Though I haven't looked to see if cherry bomb makes a stainless steel muffler yet so that will be a deciding factor.
Old 09-14-2012, 12:40 PM
DOZER's Avatar
Rep:140
This sounds do-able. I will just have to loose the 3" Y that comes with the headers which I was going to do anyway.
snrusnak's Avatar
Rep:1385
If you really want it LOUD why not run straight pipes with no muffler? So you'll have your headers with a y pipe to a single 3" pipe, then take another y pipe and reverse it so it's single in dual out for dual tailpipes.
Sean
Old 09-14-2012, 12:45 PM
DOZER's Avatar
Rep:140
Not sure I want it THAT loud. I live in an apartment complex and some times leave for work at 0630hrs and normally get home at 2300hrs.
Seems I have more research and thinking to do. Good thing I have another month or so to figure it out.
Old 09-14-2012, 01:17 PM
snrusnak's Avatar
Rep:1385
Ok. Keep in mind if you do duals with two 14" mufflers that will basically be "twice" as quiet as a single with one 14" muffler.
Maybe not twice as quiet but you get the point I think. You have twice the muffler volume.
Sean
Old 09-14-2012, 01:25 PM
DOZER's Avatar
Rep:140
I get what you are saying. At this point it will most likely be a Y and SIDO or a SIDO reversed. Although I would prefer dual tail pipes. Or what about a DIDO? I just looked at the Magnaflow site and they have those.
