Old 09-14-2012, 03:12 PM
jfthaxton jfthaxton is offline
Vehicle: 2011 dodge ram 1500
jfthaxton is on a distinguished road
Default Belltech
I recently ordered the 2/4 drop from belltech but I ordered the crew cab version for my single cab because the only options were crew and mega. After a little research I found out the spring rate is different in the kits. Will this make much of a difference? Also Ive seen some guys cutting the springs to get more of a drop. Is this very hard to do?
Old 09-14-2012, 08:08 PM
RAM EM's Avatar
RAM EM RAM EM is offline
Vehicle: 2012 Hemi express quad
Trim Level: ST express
Color: Grey
Rep:195
RAM EM has a spectacular aura aboutRAM EM has a spectacular aura about
My educated guess is it won't lower it as much as advertised, and the ride will be a little more firm. You can't return it for the correct kit? Cutting coils is simple, just need a grinder w/ a cut-off wheel, but then the ride gets even stiffer as you remove coils. I would really try to get the correct kit before you start hacking...
-DS Trinity- Hemifever tuned - 18" Magnaflow - BT catch can - 180 Tstat - 22" SRT10's - 305/45 Nitto 420 - SG 2/4 drop - blacked out heads/tinted tails - dechromed/debadged - 20% tint-
Old 09-15-2012, 10:50 PM
2011redrt 2011redrt is offline
Vehicle: 2014 RT
Trim Level: RT
Rep:25
2011redrt is on a distinguished road
I would return it for the correct kit. I think you will be all kinds of unhappy with the wrong kit cut to fit!!!
