Painted Calipers... - Page 4 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 09-17-2012, 12:26 PM
jnagel
Nice job, they look great! Hope they hold up
Old 09-23-2012, 11:49 AM
jacksonsnorth's Avatar
jacksonsnorth jacksonsnorth is offline
Vehicle: 2012 Dodge Ram 1500 QC 4wd
Rep:69
jacksonsnorth will become famous soon enough
its cave man emergency brake
I am thinking that the tech that installed my caveman test light owned that Ferd.
The Rammin' Fool from Maine
Stubby Antenna, Bed Net, Toyo Open Country tires, Bilstein 5100 Ride Height adjustable set at 2.1 ..Tow Hooks in house ready for install. More to come!
Old 09-24-2012, 08:45 PM
Miami Son Miami Son is offline
Vehicle: 2012 Ram 1500 Sport Crew Cab
Color: Mineral Gray
Rep:26
Miami Son is on a distinguished road
First mod I did after buying my truck in March. Wanted to get it done before the calipers developed any rust or road grime on them. So far, holding up great with the Dupli-Color caliper paint.
One thing, if you use a wheel brush with a twisted wire core, be careful when poking it in near the calipers. It will scratch the paint off if you aren't.
Old 06-20-2013, 03:41 PM
ArmyofOne's Avatar
Some Assembly Required
Vehicle: 2015 Ram 1500 CC 4x4
Color: Blue Streak Metallic
Rep:1260
have fun in about 2 months when they start flaking i tried vht and the hest stuff and caliper paint they all chip got me some covers instead
This was taken off truck sand blasted painted with vht put on 5 days later but like i said works for some not for others
then again maybe i just have bad luck who knows
Dude, you were right, and I will be the first one to admit it when I am wrong.
After 6 months, every one of my calipers looked like the pic above.
I took wire brushes to them, then primed with rustoleum and repainted with Duplicolor Metallic Red and Metallic Clear.
Here are the results:
Did the engine bay too:
COMBAT WOUNDED VETERAN
-2015 Ram 1500 Laramie Crew Cab 4x4. Lifted, Modded, Attitude.
2002 Lexus ES300. My Daily.
2014 Civic EX. Wifey
2008 Corvette Pace Car Convertible. #325/500
Old 06-22-2013, 10:31 PM
02325's Avatar
02325 02325 is offline
Vehicle: 12 Ram 1500 Bighorn SLT
Trim Level: Big Horn SLT
Color: molten red
Rep:29
02325 is on a distinguished road
I used the dupli-color brush on paint (not spray can) when I painted my WS6 calipers. This was back in 05 when I bought it. NOW I have only put 10k miles on it since, but have used a wheel acid to clean the wheels on several occasions and even used a heated pressure washer on them several times. I noticed this past weekend that the left rear caliper had a spot on the corner where the read has come off. These calipers are aluminum and not cast/steel. NOT sure is this makes a difference or not. I cleaned them very good with brake/carb cleaner and that wheel acid. They looked better than new when I was done. I used no primer on them either.
Good luck on the paint work. I am thinking about doing mine just to do small details.
12 RAM SLT Big HORN - GOIN BROKE BUT N STYLE
