Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 09-15-2012, 09:29 PM
P-Rez's Avatar
P-Rez P-Rez is offline
Rep:28
P-Rez is on a distinguished road
Default Huge problem!!! rain in truck!
so it has been raining the last few days and my whole passenger side floor is soaked, i pulled the panels surround the door closure and it is soaked, does anyone know where the water could be coming from? i cant find a open spot
P-Rez
Old 09-15-2012, 10:18 PM
RedRam5.7's Avatar
RedRam5.7 RedRam5.7 is offline
Vehicle: 2013 Dodge Ram
Rep:33
RedRam5.7 is on a distinguished road
Is your truck a 4 door? If so it is possibly coming from the third brake light. I have the same year model truck and sounds like the same problem. I took back to the dealer they told me this was a known problem with the 2010's but only took the about 30 minutes to fix. Hope his helps.
Old 09-15-2012, 10:25 PM
P-Rez's Avatar
Rep:28
it seems like its the front passenger side more than anything the back seat floor isnt really wet but it is moist! my driveway is a little slanted so i think thats why its in the back of the truck, im just curious because idk how it could have came in
P-Rez
Old 09-15-2012, 10:30 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
It is very common for the 3rd brake lights to leak on these trucks. Usually if that's the culprit the water will run to one or both(depending on the angle of the truck) of the rear corners of the cab and drip/run down the corner(s) of the headliner. From there it can fill the "box" under the rear seat or the floor area where your feet go.
Check the headliner. I also have a DIY thread on here on how to do a easy fix for ~$10 or $15 if this is in fact your issue. Search for it on here I think I called the thread 3rd brake light leak fix or something along those lines....if you can't find it let me know.
Sean
Old 09-15-2012, 10:53 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
like the others suggested....I removed and applied a nice bead of RTV around my 3rd brake light a few years ago.
Old 09-15-2012, 11:07 PM
snrusnak's Avatar
Rep:1388
Here's my write up if interested:
http://www.ramforumz.com/showthread....ht=brake+light
Sean
Old 09-16-2012, 12:49 PM
Spibiggie Spibiggie is offline
Vehicle: 2011 Sport CC 4x4
Spibiggie is on a distinguished road
Snrusnak's write up is more than likely the cure.
I had this same issue with a 2011 I recently bought. I noticed water on the rear passenger seat after a wash. Checked the headliner and carpet - all wet. Also, I noticed the headliner was stained from long time leaking. I got on the forumz and did a search and found snrusnak's fix, did it, and then a water test....all better now.
I went to the local dealership and they took pics to send to the mothership, and they agreed to replace my headliner under warranty. All good.
Old 09-16-2012, 01:07 PM
jacksonsnorth's Avatar
jacksonsnorth jacksonsnorth is offline
Vehicle: 2012 Dodge Ram 1500 QC 4wd
Rep:69
jacksonsnorth will become famous soon enough
It all points to the third brake light for that year truck. I did not have the issue with mine before I traded it on my current vehicle but I have read it does happen. I would check that first before I panicked because a 10 to 15 dollar fix sounds awesome. Good luc kabd keep us posted.
The Rammin' Fool from Maine
Stubby Antenna, Bed Net, Toyo Open Country tires, Bilstein 5100 Ride Height adjustable set at 2.1 ..Tow Hooks in house ready for install. More to come!
Old 09-18-2012, 05:52 PM
Kimo Kimo is offline
Vehicle: 1997 Dodge Ram 1500
Trim Level: Base
Kimo is on a distinguished road
Have had this same problem with my 1997 Ram 1500 since I bought it new. You would think after 13 years Dodge would have solved the problem. I sealed around the 3rd light with silicone but after reading this I'm going to pull it off and change the gasket. Thanks for the tip.
