Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 09-16-2012, 06:11 AM
KarateManAZ's Avatar
KarateManAZ KarateManAZ is offline
Vehicle: 2009 Dodge Ram
Trim Level: MagnaHEMI
Color: Deep Water Pearl Blue
Rep:120
KarateManAZ will become famous soon enoughKarateManAZ will become famous soon enough
Default Center console w/floor shifter
I got the center console. Has anyone done this? I want to relocate the column shifter to the console. Any ideas?
2009 Ram 1500 Crew Cab - Deep Water Pearl Blue
2/4 Drop, 0212353 Retro Shop Projector Retrofit w/ custom paint, Jet 180 T-Stat, AR LT Headers, 545rfe w/ deep pan,
Inertia Cam, Edge Triple Disk, Magnaflow 18"
Oh Yeah its a MagnaHEMI 12.2@109
Old 09-16-2012, 08:55 AM
Whitehemi Whitehemi is offline
Vehicle: 2012 Ram
Rep:17
Whitehemi is on a distinguished road
I have done this in my RC Express ...Its pretty easy if you have all the parts and mounting parts . So make sure you get all these parts in order to make it work 100 percent right . When you install the console you have to take out the drivers seat and some of the passanger to slided out the middle seat .Make sure you have the 2 mounting brackets , One goes in the back where your old 3rd seat use to mount and bolts to the floor and one goes behide the cup holders you remove to put in the console and bolts to the bottom of the dash . The plug for the 12v outlets plugs in under the drivers seat . It only fits in one plug and it works with out the need of a dealer .Make sure you have the console radio bezel as it is longer . You need wiring harness 68024883AC SHIFTER JUMPER WIRING to move the wiring in the column to the console ,It just makes your column wires longer to plug into the shifter in the console .
52109706AC LEVER MANUAL CONTROL
52104371AG BRACKET SHIFT CABLE
52855956AG GEARSHIFT CONTROL CABLE
And this is the column cover part number
STEERINGCOLUMN W/console shift, Gray 1GE44XDVAB
All this with a used console and console radio bezel are need to swap it in a truck with out a console .
This is my swap i did m Only way you can tell its not stock is i have a base cluster ....
Befor ( Not my truck but same kind )
After
Old 09-16-2012, 09:10 AM
Rep:120
Bad ASS! Thanks man that is perfect!
Rep for ya
Old 09-16-2012, 09:17 AM
Vehicle: 2012 Ram
Rep:17
If you run into anything let me know . I have done 2 swaps so far and you just need the right stuff and it works all like oem . I have had mine in for 7,000 miles and 0 issues .
Old 09-16-2012, 09:18 AM
Rep:120
I like your shifter, which one is it? I went with the Mopar t-grip
Old 09-16-2012, 09:24 AM
Vehicle: 2012 Ram
Rep:17
The one in the pick I got from billet technologys as i was looking for a shifter ball . I like the Mopar T handle alot and am thinking of switching my self . If you look up challangers they have alot of nice shifters that fit ...
Old 09-16-2012, 10:31 AM
dig dig is offline
Vehicle: 2010 1500 Dodge Ram Crew Cab
Trim Level: SLT- Big Horn
Rep:25
dig is on a distinguished road
Default Parts
Where all you finding all the part, Bone yard or buying new from dealer?
Old 09-16-2012, 06:06 PM
Rep:120
Yeah I wanted that mopar pistol grip but couldn't justify almost 200 for a couple pieces of plastic...
Old 09-20-2012, 08:47 PM
BradZ's Avatar
BradZ BradZ is offline
Vehicle: 2011 Dodge Ram QC
Rep:23
BradZ is on a distinguished road
Im actually wanting to do the exact opposite thing
Old 09-20-2012, 08:58 PM
lilcheese lilcheese is offline
Vehicle: 2012 Dodge Ram
lilcheese is on a distinguished road
Agreed...where is everyone getting the center consel
