Old 09-16-2012, 12:37 PM
Ted98 Ted98 is offline
Vehicle: 1998 Dodge Ram Magnum
Ted98 is on a distinguished road
Default Vacuum leak?
When my truck is sitting idle for about 5-10min I can start to hear what sounds like a vacuum leak. Then it will start to idle rough then if I don't feather the throttle about a minute or 2 later it will stall out. I can not see any holes in any of the vacuum lines or anything and It almost sounds as if it is coming from where the air box attaches to the throttle body. I tried tightening down the clamp to no avail.
Anyone ever had a problem like this or have any idea what could be going on?
No check engine light or anything just stalls out. But if i tap the throttle when it starts to idle rough it will go away and start the process all over again.
Old 09-17-2012, 03:04 PM
dbkid2 dbkid2 is offline
Vehicle: 96 dodge ram 5.9l
dbkid2 is on a distinguished road
this is just a thought but mine was idling rough and stalling out so i took the iac valve out and cleaned it real well with carb cleaner. put it back in it was ok for a few days then started again so i just went out and bought one. they move in and out if there stuck in one posistion they wont work properly hope this helps!!
