Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > Dodge Ram 4x4 - Offroad Discussion
Old 09-17-2012, 01:33 PM
twenty12ram1500's Avatar
twenty12ram1500 twenty12ram1500 is offline
Vehicle: 2012 ram 1500
twenty12ram1500 is on a distinguished road
Default Another Gear Question ... Help Please
Hey Guys i have a 2012 Ram 1500 Big horn with factory 3.92 gears. i have a 6" lift and 35" tires,i plan on putting 37" tires on when the 35" tires wear out... so i wanna re-gear the truck my questions are
1- what size gears 4.10 or 4.56
2- will the gears help with mpg
i also off road and go on the beach alot
Thanks guys for all the help
Old 09-17-2012, 01:58 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
I would go with 4.56s and it will definately help with the MPGs, helps turn those big tires better. There is a member on here that can modify your rear end carrier to accept 2010 gears in the back. PM me for the info!
Old 04-25-2013, 12:06 PM
03Ram2500 03Ram2500 is offline
Vehicle: 2003 Dodge Ram 2500
Color: Mineral Gray
Rep:21
03Ram2500 is on a distinguished road
I would certainly go with the 4.56 gears, I installed them in my truck and as far as MPG I didnt notice a big increase or decrease, but I went from a 4.10 gear to the 4.56. Highway MPG was never great ecspecially once I hit over 70mph. Avearage all around driving I get 11 to 12 mpg.
Old 04-26-2013, 07:34 AM
The War Wagon's Avatar
The War Wagon The War Wagon is offline
Vehicle: 1992 Dodge Ramcharger
Trim Level: LE 150
Color: Black & Grey
Engine: 1992-1993 318ci (5.2L) Magnum V8 230 hp 280lb/ft
Rep:67
The War Wagon will become famous soon enough
Send a message via Yahoo to The War Wagon
Lightbulb
My "Ram" has 35's... and I'm going 4.56's here very shortly.
I've got 200lbs of ring & pinion sets, master rebuild kits, crush sleeve eliminator, armored diff covers, and "other," cluttering up my office - I wish my mechanic would bump me up in the queue!!!
'92 Dodge Ramcharger... a work in progress...
'07 Jeep Commander... tow vehicle... :-p
Old 05-01-2013, 12:38 AM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
I got a 12 and probably was the first one to swap in 4.56.
You are already better than I started.
I had the 3.55 and 37's and it was a DOG!
Lasted 2 weeks till enough was enough and swapped out.
Love the gears. Power is back.
Never got my MPGs back to stock, but that's a given with a lift and less aerodynamics
But I'd say 4.10s for better MPG on the freeway and 4.56 for an all around daily driver
On the freeway, on 37's and 4.56 and driving 70-75, I rev at 2k
If you need pricing on some gears, let me know too. We can set you up with what you need
sales@revelperformance.com
Old 05-01-2013, 12:29 PM
brandonjansen's Avatar
Trim Level: Laramie Limited
Rep:2117
Yup, listen to fastNugly ^^ he knows his stuff!
Keep in mind on a 2012 you will have to get a front diff from a 2011 or older 4th gen in order to change the gears. For some reason Ram decided it was a good idea to weld in the gears on the 2012's and newer so you can't change them. It makes the swap fairly expensive... I'm gonna guess around $3600? Just giving you a heads up on that.
Old 05-01-2013, 12:40 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
this thread is old as dirt...relatively
Old 05-01-2013, 12:43 PM
Rep:2117
Haha, that's a good point. Definitely didn't look at the OP date...
Old 05-01-2013, 12:49 PM
Rep:1900
yea OP hasn't even been on here in a month. who knows if he's even still interested in doing this/already did it. Wish he'd come back and let us know!
Old 05-08-2013, 10:28 PM
bigrigg's Avatar
bigrigg bigrigg is offline
Vehicle: 2012 Dodge Ram 1500 5.7 hemi
Trim Level: sxt
Color: metalic silver
bigrigg is on a distinguished road
i would like a pricing!!! and how did you get the front gears swapped out? isnt the front diff closed on the 2012's thats the issue im having on my 2012 4x4!
