Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Old 09-17-2012, 10:52 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Default Race Gas Questions
Can someone with some experience wal me through the basics of race gas:
Leaded vs Unleaded
Oxygenated vs Not
I want to be able to run the 93 tune on my InTune, but all we have in OK is 91, with a few 93 stations scattered around and 5+ dollars a gallon. I would like to get a 5 gallon can of something like 100 to mix in when I go to the track. Right now, the motor is just bolt-ons, but I have a lot of stuff going together in the next few months, including a nitrous kit. Thanks guys!
Old 09-17-2012, 11:24 PM
UNBROKEN's Avatar
UNBROKEN UNBROKEN is offline
Vehicle: 2012 Ram R/T
Trim Level: R/T
Rep:123
UNBROKEN will become famous soon enoughUNBROKEN will become famous soon enough
Do some research...and don't listen to too much of what you're gonna hear here. You can do some real damage with race gas in modern motors...make sure you get it right.
If you want some real race fuel I'll send ya some of the M5 we run. It's 95% methanol, 5% nitromethane. Yes, flames will come out of your exhaust. lol
Seriously though...contact the mfg of the gas you wanna run and take their advice over anyone elses.
Old 09-17-2012, 11:33 PM
916Timmy's Avatar
Rep:1443
I just want some good unleaded 93 so I can run nitrous and not have to worry about it blowing up! I just want a good starting point. I don't want to run leaded gas, probably just some 100 mixed with 91 to give me some safe 93-95 octane
Old 09-19-2012, 02:38 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
I've run 96, 98 and 100 unleaded race gas we can get at the pump at a gas station close to here. I have tried 110 leaded but i don't have cats to worry about.
Old 09-19-2012, 03:09 PM
916Timmy's Avatar
Rep:1443
Ithink i will get some 96 and try that 93 tune out!
Old 09-19-2012, 03:46 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Half a tank of 91 and half a tank of 95 will give you 93
I'm not sure if octane booster would do the trick....never used it...but that'd be the easiest/cheapest way if it'd work. Put a $4 can of octane booster in the tank and fill 1/4-1/2 tank and run it at the track like that.
I would recommend aiming a little higher like for 95 octane with a 93 tune. When I run pump 93 gas with my 93 tune it still has to pull timing.
Sean
Old 09-19-2012, 04:15 PM
916Timmy's Avatar
Rep:1443
Thats what I was looking at 95-96 in the tank for 93 to be safe
Old 09-20-2012, 07:54 AM
Jayzsun's Avatar
Jayzsun Jayzsun is offline
Vehicle: 2012 Dodge Ram crew cab.
Trim Level: st
Jayzsun is on a distinguished road
Octane boosters are pure BS....CATS=unleaded,NO CATS=leaded...Oxygenated fuel will lean you A/F ratio by providing more oxygen in the engine...you have to find some way to run your engine a bit richer with that fuel....I'm a snowmobile drag racer with a 215 hp Skidoo Mach Z 800 1998 and i have some experimentations done with fuels...take it or give it.Rule of thumb...unless your engine NEED more octane...don't give him more...it's a lost of money.My .02
She thinks my Dodge is sexy!
Old 09-20-2012, 11:33 AM
916Timmy's Avatar
Rep:1443
Thanks for the tips!!!!
Old 09-20-2012, 08:06 PM
Jayzsun's Avatar
Trim Level: st
My pleasure...in nitrous appilcation since i have no tuner i will probably use high octane fuel when i intall the second stage...it will act as a timing retarder.Lot of infos with g**gle.
