Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Old 09-18-2012, 02:16 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
if you have bags...go with the least amount of air as possible..you want the truck to squat as much as possible from the gitgo... I try to let all the air out of mine (the solenoids keep them at least 4-5 lbs)
I'd listen to fred. My advice was pretty much the opposite, I thought more squat would be bad but he has way more knowledge on the track...
Sean
Old 09-18-2012, 02:18 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
Probably for towing/hauling. See if you can find out what brand and model they are. Maybe put a few psi in them to take away some weight transfer/squat.
you want as much weight transfer as you can get...can make a difference from spinning a little or spinning alot.... when i forget to take the air outta the bags I'll spin a bunch with the dr's/slicks... what I also found through trial and error is to not preload the caltracs either (for those who have them).. leave about an 1/8th-1/4" gap...
Old 09-18-2012, 02:19 PM
snrusnak's Avatar
Rep:1385
thanks good to know.
Sean
Old 09-18-2012, 02:45 PM
chefred112's Avatar
Rep:656
and, if you haven't tried yet either...remove the front sway bar as well, this really helps in weight transfer. I pulled mine a couple years ago and never put it back on...
Old 09-18-2012, 03:17 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Big heavy bar up there! Fred is our resident expert!
Old 09-18-2012, 03:36 PM
chefred112's Avatar
Rep:656
lol thanks...I just like tweakin.... I'll wait til he get's to the track the first time, comes back sayin "OMG, what a rush!!!", pick up the bug and say.."what next?"... then I'll mention the short belt
...for the advanced track setup..
Old 09-18-2012, 05:06 PM
Calebbrown Calebbrown is offline
Vehicle: 2004 dodge ram 5.7
Color: Patriot blue
Calebbrown is on a distinguished road
Is yur truck a daily driver though? Is it safe for me to remove the sway bar on my daily driver
If you can't RAM it,
F**K it!!!
Old 09-18-2012, 05:12 PM
Color: Patriot blue
And im actually gonne buy wheels an tires to use this weekend cause I have beg heavy 20s with 305 50 20 tires on em! Def not light!!!
I was thinking the stock dodge ram 17 that are like 18 pounds but what size an brand of tire do you suggest
F**K it!!!
Old 09-18-2012, 05:19 PM
chefred112's Avatar
Rep:656
...My truck is my daily with over 225k miles on it..I use it for everything...
I did the same thing..I ditched my 20's and found some Dakota 17's on craigslist... now, are you looking for street tires for the 17's? I run 275/60-17's on mine..
Old 09-18-2012, 05:24 PM
Color: Patriot blue
YEAh something that will grab onto the track!! An also be good on the street cause I want to do away with the 20s all together
F**K it!!!
