Tranny upgrade - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 09-20-2012, 07:34 AM
08Hemi91 08Hemi91 is offline
Vehicle: 2008 dodge ram
08Hemi91 is on a distinguished road
Default Tranny upgrade
Hey everyone Im planning on doing some work to my 08 hemi... Planning on supercharging it long with long tube headers, tuner, and exhaust.. So I know the 545rfe doesn't like power so.... What would need to be done so I wouldn't have any tranny problems. I was thinking of doing some valve body work and maybe a better torque converter
Old 09-20-2012, 08:31 AM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:627
stock pile on oem junk yard trannies. keep out of OD when doing upshifts WOTS and avoid 2P whenever possible.
Old 09-20-2012, 01:00 PM
HEMI450HP HEMI450HP is offline
Vehicle: 2010 Dodge Ram 2500
Rep:69
HEMI450HP will become famous soon enough
Transmissions have been hit or miss on these trucks. Both Sharadon and ATS make a "built" transmission, but even those have had trouble for some trucks. On the other hand, Sharadon has a 10 second ram and a couple low 11 second rams that run their stage 3 and have been for a while. I know of a few 4th gens with the ATS that seem to be happy with it, but have heard more bad then good.
Instead of droppng big money on a full tranny up front, I would start off with a Sharadon VB, a higher stall converter, deep tranny pan, and add a 1 ton cooler if your truck did not come with one already. Many guys are running this setup with great results and that is much cheaper than dropping $3-4k on a complete transmission.
Old 09-20-2012, 06:11 PM
Thanks a lot for the help might have to look into it a lil more
Old 09-20-2012, 10:19 PM
Rep:3347
Matt pretty much summed up my views as well. Coming from a guy who will be installing a NOVI 1200 centrifugal blower this winter, I've upgraded to a 2800 stall converter, Stage III valve body, and a deep sump pan.
Old 09-20-2012, 11:01 PM
Rep:69
Do you have a transmission temp gauge yet? Also, which transmission cooler do you have up front?
Even with my 370" stroker, I was only seeing about 185* max transmission temp with the transmission mods listed above. Temps stayed about the same even with the full stage 3 transmission as well.
Old 09-21-2012, 02:15 AM
Rep:3347
I have the tow package, so I have the OEM 1500 tranny cooler and I have the deeper sump pan that I added. I hadn't thought about a tranny temp gauge, wouldn't be too hard to do, I've got a free space in my overhead triple gauge pod for one. I'll pick one up when I have positive cash flow again and if temps start rising I'll swap to the 1-ton cooler.
Old 09-21-2012, 08:48 PM
KarateManAZ's Avatar
KarateManAZ KarateManAZ is offline
Vehicle: 2009 Dodge Ram
Trim Level: MagnaHEMI
Color: Deep Water Pearl Blue
Rep:120
KarateManAZ will become famous soon enoughKarateManAZ will become famous soon enough
I have the ATS built trans. It has been running since November last year with no problems. That's with 488rwhp and instant tq through it... I am finishing up my truck in the next month or so and I believe it will be around 600rwhp so we will see how it holds up
2009 Ram 1500 Crew Cab - Deep Water Pearl Blue
2/4 Drop, 0212353 Retro Shop Projector Retrofit w/ custom paint, Jet 180 T-Stat, AR LT Headers, 545rfe w/ deep pan,
Inertia Cam, Edge Triple Disk, Magnaflow 18"
Oh Yeah its a MagnaHEMI 12.2@109
Old 09-21-2012, 09:23 PM
UNBROKEN's Avatar
UNBROKEN UNBROKEN is offline
Vehicle: 2012 Ram R/T
Trim Level: R/T
Rep:123
UNBROKEN will become famous soon enoughUNBROKEN will become famous soon enough
I'll be using ATS for my built trans also.
