Old 09-21-2012, 11:42 PM
lawrence s crowe's Avatar
lawrence s crowe lawrence s crowe is offline
Vehicle: 2012 Dodge Ram
Trim Level: st
Rep:12
lawrence s crowe is on a distinguished road
Default P 0306 code
during hunting low speed and low revs had code 306 come up after start up. Then a tapping noise start then goes. Had it tolled back to town. start up to put in the shop. Now there is no tapping noise. any ideas guys and gals before the mack - n - nicks get there hands on it. 2012 5.7l 1500 Hemi with the fuel saver what that does
Its a MOPAR thing :)
Old 09-22-2012, 12:33 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
how many miles? misfire cylinder #6...I would pull the plugs on that cylinder and compare to the others... I would clear code and see if it does come back, if it does, i would swap coil packs (with any other one) and see if the code follows (then it would be a coil pack issue).... and/or remove coil packs on passenger side valve cover and remove valve cover. Inspect the valve springs and look closely at the cylinder 6 valve springs for any breakage (which would cause valves to tap)
Old 09-23-2012, 12:19 PM
Trim Level: st
Rep:12
Code had been cleared and the oil changed since it was due. ( every 5k ). No problems the load ticking has since been silenced. Still have the Hemi Tick, talked a Chrysler Canada Rep, and a 5.7L expert, 3 Mack - N - Nicks. most of them agreed that dirty oil can screw with the MDS and cause a lifter to hang up.
Old 09-23-2012, 02:36 PM
Vehicle: 2012 Ram Express
Rep:63
Good to hear. I was thinking maybe your were on an incline or off camber terrain and might have managed to starve the oil pump for a split second.. if that is even possible with our engine's oiling system.
Old 09-23-2012, 03:42 PM
Rep:2642
I don't know about up in Canada, But
down here the 2009 has a Lifetime Power Train Warranty
engine, transmission & rear end, are taken care of for the Life of the vehicle, no charge to me
of course, i have to pay for regular servicing
