Fog Lights - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Old 09-20-2012, 04:18 PM
toprjf739 toprjf739 is offline
Vehicle: 1997 Dodge Ram 1500
toprjf739 is on a distinguished road
Default Fog Lights
I would like to put OEM fog lights on my 97 Ram. Can I buy the OEM parts and plug them into the existing wiring harness. I should be able to install the switch where the blank switch is now. There should be a plug in the dash for it. I would also have to install the relays in the box under the hood. I think the wiring harness for the fog lights should plug directly into the existing wiring harness. am I correct in my thinking?
Old 09-22-2012, 12:55 AM
ray5.9rt ray5.9rt is offline
Vehicle: 2005 dodge ram 1500 4x4
Color: LT BLUE
ray5.9rt is on a distinguished road
that sounds right only problem with stock hook up is that the fog lights will turn off when you turn on your high beams,but if you go with a 2nd switch and relay and tap in to the park lights the fog lights will stay on with high and low beams or just park lights...hope this helps
