Old 09-20-2012, 09:11 PM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1195
Default TQ Converter noise...
Is it a grinding or does it sound like a playing card in a bicycle wheel?
When I take my foot off the gas to coast at speeds over 20mph, I get a sound that sounds just like this, but its very very faint. If the windows are up or its noisy around you it cant be heard inside the truck. But if you are in a neighborhood its nuts!
US ARMY-RETIRED
2015 Ram 1500 Laramie 4x4 Crew in Blue Streak Metallic Pearlcoat-Mopar spray-in Liner, Mopar Mud Flaps, 20% tint, Mopar Side Steps, Best-Top Tri-Fold Bed Cover, DZ Tailgate assist.
2002 Ford Focus ZTW Wagon-loaded, tinted and tunes. 183k miles and counting...
Old 09-21-2012, 07:08 AM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:358
TransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really nice
The converter "warble" noise is typically under light cruise conditions (not coasting). I think the best description is that it sounds like a frisbee sliding across concrete.
Old 09-21-2012, 09:52 AM
mineralram's Avatar
mineralram mineralram is offline
Vehicle: 2015 Dodge Ram
Rep:166
mineralram has a spectacular aura aboutmineralram has a spectacular aura about
Your symptoms are the exact same as mine where, The dealer replaced my torque convertor and all the bad went away and it is as quiet as a mouse now
Old 09-21-2012, 09:02 PM
ArmyofOne's Avatar
US Army Retired
Rep:1195
TransEngineer, I am reporting back....dealer says it was a "thrust bearing" in the converter. Replacement part has been ordered. Great service at Tacoma Ram/Dodge/Chrysler/Jeep!
US ARMY-RETIRED
Old 09-26-2012, 10:52 PM
Fatalwishes Fatalwishes is offline
Vehicle: 2011 Dodge Ram CrewCab 4x4
Fatalwishes is on a distinguished road
I get what I can explain as a "fan noise" Like a electric fan turned on but it does it when i feather the throttle around 20mph.
I'm thinking this is the Torque Converter issue?
Old 09-27-2012, 07:23 AM
Vehicle: N/A
Rep:358
The T/C noise is typically heard at higher speeds (under very light cruise), like ~50 mph. I don't think a noise at 20 mph would be this particular problem.
Old 09-28-2012, 08:45 PM
ArmyofOne's Avatar
US Army Retired
Rep:1195
turns out it was, the replaced the converter.
Part # they removed was U8051146AB
Reinstalled part # is R8051146AB
US ARMY-RETIRED
Old 10-01-2012, 11:23 AM
Spdbird Spdbird is offline
Vehicle: 2011 Dodge Ram Sport
Spdbird is on a distinguished road
Default Slippage
Mark (Trans Engineer)
My problem is when I go into passing gear it is a "crisp and clean" shift. When it comes out of passing gear (5000 rpm) it feels like their is slippage and not a clean shift. It does not "slip" all the time. One time while coasting, I then reapplied throttle and truck shook bad. Just that one time. I got TSB 18-023-11 printed to take with me to the dealer, also have the tech remove all shift points and let the trans relearn. Thanks.
