Old 09-21-2012, 09:48 AM
fat frank fat frank is offline
Vehicle: 2012 dodge ram 4 X 4
Trim Level: lonestar
Rep:14
fat frank is on a distinguished road
Default Tongue Wt on 4x4 with Leveling Kit
I have a Daystar 2.5" leveling kit for my 4x4 and haven't installed it yet. I understand it will raise my front by 2". Concerned with the nose up attitude when towing. Has anybody here ulled a trailer with the leveling kit installed? How much sag did you get in the back. Wheel wells measure 40" in rear and 36.5" in front now. I think the kit will bring the front up to 38.5".
I'm talking of pulling a Lite trailer with around 400 lbs of tongue weight. Will I need air bags in the rear to keep it safe.
I guess I could ge a couple of big boys to stand on the bumper and see what it does now.lol Just curious how it hadles wdith a trqailer in tow.
Any help here would be asppreciated.
Thanks in advance
2012 SLT 4x4; 5.7 Hemi: AirAid CAI; 2 1/2" Daystar leveling kit; Cabin AF installed; Black aluminum tool box; Front Receiver Hitch in near future.
Old 09-21-2012, 01:03 PM
DOZER's Avatar
DOZER DOZER is offline
Vehicle: 2006 Ram 2500 Quad cab 4x4
Color: Atlantic Blue
Rep:140
DOZER will become famous soon enoughDOZER will become famous soon enough
Send a message via Yahoo to DOZER Send a message via Skype™ to DOZER
I realize we have different trucks but I hope this helps. I have a HBS 2" level in mine and towed this with minimal squat in the rear. I would suggest hooking it up and see. If necessary get air bags.
'06 2500 ST 4x4 Quad cab, Vararam CAI, Bed/Hood stripes, Vent visors, Bully tailgate lock, Moto Metal 909 18x9, Nitto Terra Grapplers 295/70/18 HBS 2" level, Bilstein 5100's, Bushwhacker flares, 5000K HID's, Diablo Trinity 87 tune, LineX, Bakflip F1.
Old 09-21-2012, 02:23 PM
Ramsh70's Avatar
Ramsh70 Ramsh70 is offline
Vehicle: 2012 Ram Laramie Crew w 3.92s
Trim Level: Laramie Loaded!
Color: Black n Silver
Rep:22
Ramsh70 is on a distinguished road
I did 2.1" lift in front with the Bilsteins and I pull a 6000# boat with mine with about 600# tongue weight...... had a bit of sag... no biggie but it made me nuts so I put in Airlift 1000 helper bags in the coils... Problem solved for $100 bucks!
UNDERCOVER SE, HuskyLiner Flare Friendly Mudflaps, AVS INChannel Ventshades, De-badged Doors, Billet Technologies Catch Can, Black Quad Headlights - 6000K 35W HID Low beams and 4300K 35W HID fogs -Lumin-X'd, Bilstein 5100s x 4 - fronts set at 2.1, Airlift 1000, Flush mount Air pressure gauge in rear bumper, Mufflex 18" Magnaflow, 285 60 R20 GoodYear Wrangler Duratracs, Interior LED Floor lighting, AMP RESEARCH BEDSTEP, WOLO Amber "hidden" strobe lights ....and thats so far.
Old 09-21-2012, 04:43 PM
jc4041's Avatar
jc4041 jc4041 is offline
Vehicle: 2009 QC 4wd
Rep:146
jc4041 will become famous soon enoughjc4041 will become famous soon enough
moved wife and kids to Cali before heading to Korea.....5k lbs in the uhaul trailer....but I had ordered the Air Lift bags before we loaded everything up. Never had any issues.
Ram DSP, CAI, Cherry Bomb Extreme, AirLift 1000
'07 Dodge Charger SRT8 SuperBee #579-CAI, DSP, dual Cherry Bomb Extremes
'07 GCSRT Stock
Old 09-21-2012, 06:01 PM
Miami Son Miami Son is offline
Vehicle: 2012 Ram 1500 Sport Crew Cab
Color: Mineral Gray
Rep:26
Miami Son is on a distinguished road
I'm pretty sure tongue weight is a function of the trailer hitch and is not supposed to be exceeded regardless of what vehicle is involved. It is a measure of how the load is distributed and not really tied to how much a vehicle can pull. You can have too much tongue weight and still be well under the towing capacity. Excessive tongue weight affects weight transfer and handling because it makes the front end too light, especially when braking.
Old 09-21-2012, 09:01 PM
dodgeboy360's Avatar
Vehicle: 2015 Dodge Ram
Color: Granite
Rep:505
i got a 2'' level kit in my 2012 and i had the back filled with fire wood and also a trailer on the back loaded with wood she was squattin pretty good but towing wasent an issue handled alright and everything
Trailer tow package, husky liners, timbrens, more to come
Old 09-21-2012, 09:40 PM
TRCM's Avatar
TRCM TRCM is offline
Vehicle: 2012 Ram Laramie 4x4 CC
Color: White w/silver trim
Rep:63
TRCM will become famous soon enough
If the tongue weight makes your truck drop 2" without the leveling kit, it will still drop 2" with the leveling kit. My boat has a tongue weight of ~ 300 lbs, so I'd expect yours may drop up to 3", as mine drops ~ 2".
So, if you raise the front to within 1.5" of level as you mention (38.5" front, 40" rear), then when towing, the front will be 1/2" higher than the rear at a minimum if your tongue weight drops you 2".
You need to figure out how much the tongue weight drops the rear unleveled, and then make sure the front is at least that much lower when leveled to avoid the front being higher than the rear when towing
1996 Cherokee Sport 4x4
1988 Cherokee Pioneer 4x4
Old 09-22-2012, 08:41 AM
Rep:14
Thanks for all of the responses.
I'll be traveling with a light travel trailer with only about 380 to 400 lbs of tongue weight and the total weight of said trailer is around 4000 lbs which should not be an issue with this truck. Just for peace of mind, I want to keep the front down for obvious reasons. I guess the air bags are the way to go.
Can the air bags be intalled to run empty until needed? Or should I say with low pressure.
Is there a sticky on here showing install?
Thanks in advance.
Old 09-22-2012, 11:20 AM
Asur Asur is offline
Vehicle: .
Rep:4371
run your airbags with about 10lbs in them, you should be good.
most that have installed them, then run the hose to the rear plate on the hitch. makes for easy access and looks clean.
Old 09-22-2012, 12:13 PM
Ramsh70's Avatar
Rep:22
I put my air valve next to my trailer wire plug in the bumper... I run 5-10 pounds empty and 25-30 pounds to stay level with the boat on... helped with the high beam flashes too i used to get with the nose high.... truck handles great! you'll have no issues!
