Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Place your Ad Here!
Old 09-22-2012, 09:33 AM
Dukeman Dukeman is offline
Vehicle: 2010 1500 Ram
Color: Inferno Red
Dukeman is on a distinguished road
Default Mixing oil brands
What's your take on mixing oil brands (not types). I have 5 liters of one brand and I have 2 of another brand, both full synthetic. Good idea, bad idea or somewhere in between.
Old 09-22-2012, 09:56 AM
Grubrunner's Avatar
Rep:3883
I'm assuming you're speaking of the same viscosity, correct?
Grub out!
Old 09-22-2012, 09:57 AM
gopackgo69's Avatar
gopackgo69 gopackgo69 is offline
Vehicle: 2014 Ram 1500
Rep:20
gopackgo69 is on a distinguished road
Yeah same viscosity, no problem.
2014 4x4 Hemi sport , 3.92, Pro-comp level 2.75", Rear Fox 2.0, 1.5" springs, Diablo 93 Tuned. Toyo AT2 295/65/20
Old 09-22-2012, 10:48 AM
Rep:3337
No issue, go ahead and do it. It's only if you're a picky purist like me who only uses grade IV synthetic that it makes any difference, and then it would mean I have to change at 10,000 miles and not 15,000 if I added grade III syn.
Old 11-20-2012, 10:52 PM
craigsez's Avatar
craigsez craigsez is offline
Vehicle: 2010 ram 1500 sport
Trim Level: 10/1500 sport
Color: mango tango
craigsez is on a distinguished road
Change yer oil same time no matter if its mineral or not....Only diff in syn and mineral is the additive package..Syn is better in most cases but its the additives that wear out and not the oil itself...Only way the oil gets bad(for the lack of a better term)is because the oil itself gets over come with impuritys..
You got it,a truck brought it!!
Old 11-21-2012, 04:49 PM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:782
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
i tend not to do this as the additive pkg are different. i don't know if they will work together or chemically alter the package. this is most likely old thinking on my part though.
Old 11-22-2012, 11:00 AM
ridgerunnerseoinc ridgerunnerseoinc is offline
Vehicle: 2010 2500
Rep:134
ridgerunnerseoinc will become famous soon enoughridgerunnerseoinc will become famous soon enough
I've mixed diff. types of oils, diff. brands, diff yrs of oil, and diff. visc. of oils. Really doesn't matter much at all. I've freeked more than a few purists on www.bobistheoilguy.com with my oil mixes and UOA's.
Old 11-23-2012, 02:19 PM
craigsez's Avatar
Color: mango tango
For the most part oils will have pretty much the same additives..Some will have a lil more of one and less the other and another brand will be the opposite...There is a company called polaris(no not the snow machine/4 wheelers ect)that chemically tests oils...They should have somethin on their site i would imagine...I know they do oil sampling/testing for wear metals and additives for a radio show on sirius for big rigs..
Old 11-23-2012, 02:24 PM
craigsez's Avatar
Color: mango tango
Just not a good idea to mix viscositys...hell you can mix syn and mineral if you wanna..Some engines dont like the sudden change of mineral to syn so every oil change just swap one mineral for a syn till its full syn..If you find that she goes through oil a lil its most likely the rings reseating..
Old 11-23-2012, 03:37 PM
Rep:2920
First a little background
I was raised on a farm in Connecticut, when we bought our oil it came in glass jars, with a metal screw on lid & spout, like this..
http://imagehost.vendio.com/bin/view...g,bottles6.jpg
We returned the empty jars to get more oil.
When more & more companies started making oil, One or 2 of the companies were located in Pennsylvania, Quaker State was one of them. If you were to mix or change oil, like go from Texaco Flying A Brand motor oil to Quaker State, or just mix the 2,
pretty quickly you would discover that the oil from Pennsylvania was not compatible with any other oil, it would gum up your engine with a yellowish snot like goo.
I don't know if they still have Pennsylvania Crude Motor Oils made the same as in days of old.
I believe that this was where original DON'T MIX OILS came from
I still won't mix oils unless i am down a quart & can't get my normal brand
DUKEMAN, If it were me, those 2 cans would stay on the shelf in the garage, until a friend needed some oil & then it would be gone.
To this day, i will not mix oil brands
When i first bought my '09 Ram, Mobile oil had the Chrysler oil contract, about a year later, i believe Valvoline won the contract, then last year Shell won the contract. Shell Oil is Pennzoil for gas engines & Rotella for diesels.
That is when i changed to Mobile One synthetic & WIX oil filters
