Old 09-22-2012, 09:13 PM
deedub97gt deedub97gt is offline
Vehicle: 2002 Dodge Ram 1500 SLT
deedub97gt is on a distinguished road
Default front diff & lift question
Alright so im going to get some 4:11 gears front and rear, i can find rears all over the place. what specifically am i looking for, for a front diff?
is it the reverse ring and pinion im seeing on a few websites?
and of course i know to replace the bearings and seals while im in there.
now for a lift, i would prefer a 4" suspension lift. but i cant find a single thing other than body lifts for a 02 ram, and i already have a 2.5" body lift...any help here would be amazing!
And lastly does anyone have a link to a site that they know sells the gears im looking for? i drive a 02 ram 1500 5.9L if you need that info
Old 09-23-2012, 01:05 AM
TRCM's Avatar
TRCM TRCM is offline
Vehicle: 2012 Ram Laramie 4x4 CC
Color: White w/silver trim
Rep:63
TRCM will become famous soon enough
A reverse ring & pinion may not be what you need.
A reverse ring & pinion is reverse cut, and not all front diffs are made that way.
You need to determine what you have, and get the parts for that.
I don't know if dodge ever used a reverse cut ring & pinion. My 79 had a standard ring & pinion in the front, so make sure before you buy.
Some of my research shows a Dana 44 is the center section, and some of it says it is the 8" IFS, so you need to do some checking before you spend your money.
From what I see, yours is a standard rotation diff.
I'd go to randys ring & pinion website and use their diff wizard
1996 Cherokee Sport 4x4
1988 Cherokee Pioneer 4x4
Old 09-23-2012, 01:57 AM
Thanks TRMC
little bit of research shows the rear is 9.25" (i knew that much)
front is a 8" -- also knew that -- and its standard. so i just need to find a set of 4:11 for it bearings/ selas/ and start getting my hands dirty. book says its about the same as doing a rear except im sitting in a different spot. easy enough. thanks!
anyone have any hits on a lift?
Old 09-23-2012, 11:22 AM
dezertrunner dezertrunner is offline
Vehicle: 2001 Ram
Trim Level: Base
Color: Blue
dezertrunner is on a distinguished road
What size tires are you going to run?
Old 09-23-2012, 02:53 PM
its had 35" tires on it when i bought it, and i like the way they look and grab so im going to keep running the same.
Old 09-24-2012, 08:39 AM
Vehicle: 2001 Ram
Trim Level: Base
Color: Blue
If they clear what do you need a lift for then? Nothing looks sillier then a lifted truck with small tires.
Old 09-24-2012, 10:21 AM
4 inches of lift wouldnt look too bad. and i have a decent sized stream running through my property, i can make it through with the 3" lift but it gets pretty iffy after a rain storm or something of the sort. and also going over logs and rocks. already cracked one transfer case on a rock.
Old 09-24-2012, 10:24 AM
also, i have been reading with this gear thing. it says in order to run a 4:10 or bigger in a dana 40 you need to get "thick" gears? anyone heard anything about this? and as usual thanks for all your help!
Old 09-25-2012, 07:08 PM
Vehicle: 2001 Ram
Trim Level: Base
Color: Blue
How is a lift going to help you with transfer case clearance? Overall clearance is dictated by tire size, not lift. I always laugh when I see trucks that sit higher then my own, with tires the same size or smaller.
Old 09-25-2012, 09:10 PM
TRCM's Avatar
Rep:63
Really ???? If they sit higher than yours, but with the same size tires, their transfer case also sits higher than yours.
As lift increases the transfer case moves up with the frame. This is why in some situations you have to employ a transfer case DROP to help with driveline angles.
So, if you put a 6" lift on a stock truck, the frame AND transfer case will sit 6" higher than it did. It doesn't matter if the tires are still stock, the tcase WILL sit higher.
Now, a lift DOES NOT help with the axles, it's the tires that raise the axle up.
