Old 10-02-2012, 11:23 PM
Originally Posted by readster1 View Post
I have already talked to a company in Vancouver and was looking at a 4.5" offset but I think I will have to lift the front about 2" to keep them from rubbing on the bumper the bilstiens should be the fix,now how did you get the 456 gears to fit you diffs??
4.5 is good and you should clear without the Bilsteins.
But I would still do the Bilsteins anyways....
Gears?
The rear is similar to doing them in an '11 and the front diff CANNOT be used and a '10 or '11 diff needs to be used
Old 10-02-2012, 11:38 PM
readster1's Avatar
Vehicle: 2011 dodge ram
Trim Level: Long horn/sport
Color: brilliant black pearl
Rep:12
Gears?
where did you get them done and what brand,I looked into it at the beginning of summer and was told that the 11's and 12's were not available because they changed the diffs to a z diff or something and there were no 456 gears that would fit,don't know a lot about it I just know that I would benefit having them with bigger tires especially 37's,I find it to be a little sluggish with my setup now and I have 392 gears.Oh yah I was looking at Yukon gears
Old 10-03-2012, 12:20 AM
Man, you have am 11? All you gotta worry about is your rear. The shop has to machine the carrier to accept the bolts of the gear from the previous years
Old 10-03-2012, 12:44 AM
readster1's Avatar
Rep:12
Thanks for all your help I will look into it again
Old 10-03-2012, 01:43 PM
No Problem bud!
