Old 04-09-2014, 03:13 PM
dizzle dizzle is offline
Vehicle: 2013 Ram 1500 Ext. Cab 4x4
Color: True Blue Pearl
dizzle is on a distinguished road
good video. much easier to get straight lines when its still wet.
Old 04-09-2014, 03:57 PM
Elderado's Avatar
Elderado Elderado is offline
Vehicle: 2014 Ram 1500
Color: Deep Cherry Red
Elderado is on a distinguished road
go here and view install, it shows how to remove grill.
http://moparonlineparts.com/1500-grille-p-4232.html
Do not show any fear, squids can sense fear.
Old 04-09-2014, 10:11 PM
Liredneck Liredneck is offline
Vehicle: 2009 1500
Trim Level: TRX4
Rep:15
Liredneck is on a distinguished road
That's a shame cause that looks bad ass, hope you do it again in the future
Old 04-09-2014, 11:22 PM
Robs 98RAM's Avatar
Robs 98RAM Robs 98RAM is offline
Vehicle: 1998 Dodge Ram
Color: Blue
Robs 98RAM is on a distinguished road
Yeah as its already been stated, if there isn't a gap that will cut the dip, you need to remove the tape immediately after the last coat is applied. You probably have already peeled it off and redone it, but they sell a repair kit that is just basically lacquer thinner. It thins the edge of the ragged dip so you can respray over it.
Old 04-10-2014, 12:04 AM
MitchellBoyz's Avatar
MitchellBoyz MitchellBoyz is offline
Vehicle: 2013 Ram 1500 Express
Color: Bright white.
Rep:33
MitchellBoyz is on a distinguished road
If you look at some of one of my threads i got a bunch of pics on some stripes i did with plasti dip a while back ago.
The way i did it is, i prepped way more then i should have carefully planning on how the tape will come off. When you peel the tape that decides your edge, you don't want to bring off any other pieces of tape you didn't want to come off at that time.
Here's a trick to any one wanting to leave nice crisp clean edges, AND ALSO letting it dry in between applying 4-5 coats. The trick is to spray with all of your desired coats with drying in between. But on the last coat as soon as you get done spraying it, peel the tape off exactly the way the guy did in that video.
It doesn't make sense at all how it works, but it does. I guess it kinda re-wets/re-activates the plasti dip. It works a lot better then one thick coat method, because most of the time you will get runs and a rough finish with the one thick coat method.
If anyone has anymore questions let me know.
2013 Bright white Express crew 4x2, AKA Stormtrooper
Old 04-10-2014, 02:01 PM
SShadow1974's Avatar
Vehicle: 2014 Ram 1500 Outdoorsman
Trim Level: Outdoorsman
Rep:156
^^^ +1 Agree with MitchellBoyz
S S H A D O W
Old 07-08-2014, 09:30 PM
1000MAX's Avatar
1000MAX 1000MAX is offline
Vehicle: 2012 1500 Express
Trim Level: ST Express
Rep:18
1000MAX is on a distinguished road
The trick with Plasti-dip is to tape past the crease where you want a straight line. once the Plasti-dip is dry. You will be able to peel the overage of Plasti-dip off. giving a clean edge where the crease is. Just my two cents
DiabloSport DCX w/Hemifever tuning, Vararam Intake, Air lift 1000 springs more to come.....
Old 07-10-2014, 06:24 PM
flyhiguy85's Avatar
flyhiguy85 flyhiguy85 is offline
Vehicle: 2012 Ram 1500 4x4
Rep:20
flyhiguy85 is on a distinguished road
Originally Posted by ndcart View Post
First of all, I commend you for your elaborate prep work.
I've found that to get clean edges, you have to peel the tape while the plastidip is still wet. Makes it tough to get all of the coats you need. I just don't wait as long in between coats. I lay them down pretty quickly, then peel the tape ASAP. Seems to work pretty good.
Yep, yep. Five coats of anything, letting it dry, then peeling the tape is a no go....it's the same with conventional latex house paint.
Vararam Intake, Cabin Air Filter, 5% Window and Brow Tint, Blacked Out Tails and Cargo light
Old 07-16-2014, 07:49 PM
DieselD DieselD is offline
Vehicle: '14 Ram1500 BigHornEcodiesel
Rep:16
DieselD is on a distinguished road
Looking to add to this. I recently did my first plasti dip application to "RAM" letters stamped into my new stirrup steps. I didn't see these threads and did 5 coats over several days and went. To remove the tape while dry and I got the same disappointment.
Since then, I've sprayed it once and then thought to read up on it here. Now that I have the one coat down, should I do 3-4 more coats all within an hour and then peel the newspaper masking while wet?
Old 07-16-2014, 08:25 PM
Rep:156
The way I did it, I sprayed 5 coats with 10 minutes in between each and on the last coat immediately peeled the tape. Worked perfectly.
S S H A D O W
