Old 09-27-2012, 08:30 PM
Rep:2657
I believe that down in the fill tube, there is an Anti Siphon device
I believe that you can see most all of the fill tube by looking between the outside sheet metal & the frame
look for a kinked hose
I don't know about now, but it used to be that you took out 2 screws just inside the fill cap door & 1 or 2 more closer to where the tank & fill tube connect. Then you just pull the fill tube right out at the fuel door
Old 09-28-2012, 02:05 PM
rdsabin rdsabin is offline
Vehicle: 2012 Sport Reg Cab 4x4
Trim Level: Sport Reg Cab
Color: Mineral Gray Metallic
Rep:186
rdsabin has a spectacular aura aboutrdsabin has a spectacular aura about
The 2010 I had had a similar problem from day 1. The dealer ended up replacing my tank under warranty, but I am sure yours is over the warranty coverage period.
2012 DodgeRam 1500 4x4, 20% Tint, Running Boards, Class IV Hitch, 14" Win Muffler, Catch-Can, Tow-Hooks, LED Tailgate Bar
2008 Dodge Supe Bee, Catch Can, Backup Camera, 20% Tint all windows, CAI, AFE Filter
Old 09-28-2012, 02:55 PM
Mophead's Avatar
Mophead Mophead is offline
Vehicle: 2012 2500 4x4 Crew
Trim Level: Bighorn
Mophead is on a distinguished road
Had my brand new 2500 do that. When I looked underneath for vent lines I found a black tube running from the top of the back of the tank to a big (2x2x1) vapor recovery system next to the transfer case. That black tube was kinked. When I moved the kink out of it, she accepted fuel.
The rest of the story.. It turns out mfg have gotten away from fuel hose and now use this black tubing instead. It's much lighter weight and I'm sure much cheaper. Yeah cheaper....It does say "fuel" on the side, so I assume it is specially rated for it. The problem is this is very thin walled and once it gets a kink in it, it's always there. Mine was routed poorly thus createing to tight a bend and wala kink. Yours may have been installed properly and somehow came out of the clips and got a kink. (this may not be your actual case though I'd bet) The part that burns my ass is my salesman filled my truck up just prior to handing me the keys. He had to see the problem and didn't say word one. Then to make matters worse, when I took it back when I saw the problem they put it on the rack put therer hand on the part and ordered the wrong one. Make that ordered the wrong part 5 times after looking at it. I'll give them the benefit of the doubt that the parts schematic is very inconclusive. Just poor customer service though. I still don't have it permanently repaired (I have it wire tied to keep the kink out) because I don't want to deal with the dumbshit. When I do take it back they are gonna order every part on the schematic or I'm going to Ram. I'm glad it isn't a line thats under pressure. Actually kinda wish the thing would burn to the ground so they'd have to give me a new one. not really.
Old 09-28-2012, 03:33 PM
Rep:2657
When i went to buy my locking tailgate, the parts dept. ordered the correct handle, but not the actual part that causes it to lock
My Service Writer went with me to look at the inside of the tailgate
He took a picture
while he was taking off the tailgate access panel
i found a Laramie that had a locking tailgate on the sales lot
he took off that Rams access panel & took pictures
Then we walked into the parts dept. & showed the parts guy the difference
He ordered the correct part,
The images on the parts dept. computer were blurred & the words were difficult to read
I could see how there may be a mix up
this is the main part of the LOCKING tailgate
same part, but for the NON Locking tailgate
Old 09-28-2012, 06:33 PM
persuazion persuazion is offline
Vehicle: 2008 Dodge Ram 1500
persuazion is on a distinguished road
Weird,I went to try it out again today and filled the other half of the tank up with not one problem. Seems like it was a one time thing......hopefully.
