Old 09-29-2012, 11:20 AM
Jon89 Jon89 is offline
Vehicle: 1999 Ram 5.9 V8 1500 Series
Trim Level: Laramie SLT
Jon89 is on a distinguished road
Default Mysterious Coolant Loss....
1999 Ram 1500-series 5.9 V8 short-bed with 64,000 miles....
For the past month or so I have noticed a faint whiff of coolant at engine start-up with the windows down. No evidence of leaks on the ground underneath the truck, no coolant mixed in with the oil or ATF. no unusual smoke coming from the exhaust, no wet hoses or joints in the engine bay. Temperature gauge continues to register in the normal range. I've had to add a small amount of coolant to the expansion tank a couple of times during that period, just a half-inch or so....
I last drained and flushed my coolant system in February 2010 just because it had been quite a few years since doing so. No coolant issues before or since....
Where could such a small amount of coolant be going?
Old 09-29-2012, 07:12 PM
moparornocar72's Avatar
Rep:630
a/c compressor maybe??? I would add some dye into it and keep running it
14.268 @ 95 MPH Full Trim
Old 09-29-2012, 10:01 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
My '90 had a cheap part plastic replacement radiator that turned out to have a penchant for cracking. It took a while for it to be bad enough to start leaving a puddle, thought my water pump was fading. Had all the symptoms you speak of. Not sure what yours is made of, but it could be a pin-holed hose somewhere. Best time to look for a leak of any kind is right after shutdown as heat and pressure actually rise. What you're smelling is probably pooled coolant from the previous shutdown. At startup the engine fan is blowing it to the sir, then you smell it. Look especially for evidence of pooling on the intake manifold around coolant lines and the thermostat housing.
Old 09-29-2012, 10:15 PM
Rep:2616
It could possibly be your Plenum Gasket, but that is mostly oil loss, but could also cause coolant loss
Old 09-29-2012, 11:08 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Mine leakes arround water pump intake for heater hosr right under compressor so its hard to see most of the time its just a matter of replace spring clamp with a standerd clamp. But don't be surprised if the leak moves elsewhere. Mine moves from one to the next weakest. Mine started at lowe hose at water pump to radiator now its at water pump.
Old 09-29-2012, 11:25 PM
Okiespaniels's Avatar
Okiespaniels Okiespaniels is offline
Vehicle: 2000 Dodge 1500 QC 4x4
Trim Level: Fleet
Rep:47
Okiespaniels is on a distinguished road
I 've a terrible time getting my system to seal...radiator side seal, stat gasket, freeze plug, heater core and last (and hardest one to catch) but not least, a missing clamp on the coolant recovery tank hose at the radiator. The stat gasket stunk something awful but I didn't find it until I did my plenum.
Old 09-30-2012, 12:59 PM
Thanks for the various suggestions. I'll take a closer look at the various coolant hose connections as well as the radiator. Maybe I can spot something I missed before....
Old 09-30-2012, 01:27 PM
BeefcakeTheGirl's Avatar
BeefcakeTheGirl BeefcakeTheGirl is offline
Vehicle: 2000 Dodge Ram 1500 Sport 5.9L
Color: Black Crystal
BeefcakeTheGirl is on a distinguished road
i would check your freeze plugs def, i had 2 leakin an ever-so-slight amount of coolant over long periods of time. the ones that were leakin on my 5.9 were the ones on the driver side, right by the starter and a motor mount. check those and also the ones on the front and passenger side. i'd recommend changing them to the brass ones so they last longer n stronger, also, buy a few extras: freeze plugs like to be a pain in the ass and may misshape themselves if u dont have the right tools. if you go to oreillys, the part number for dorman is for the 6cyl so u gotta call dealer and cross their part number with oreillys. hope that helps ya out. ~beefcake the girl
~All I need is my truck and my dog~
Old 09-30-2012, 03:36 PM
Rep:85
There are no coolant passages associated with the intake plenum gasket.
Old 10-08-2012, 06:47 PM
kccode1
+1 for the freeze plug. That is how mine started. Just low in the tank. no drips etc. Now I get a small puddle when I fill it but not after it leaks down. Most likely the rear upper plug. Getting ready to do all of mine.
